: 96' Northstar coolant leak
Ronnie Fierro
10-05-13, 09:57 PM
I've got a 96' Eldorado ETC Touring, 4.6 Northstar with a major coolant leak, it leaks out almost as quickly as you pour it in. The general location is on the passenger side of the engine and behind/under the heater core, I do know it's NOT one of the two metal heater lines. The leak is not visible at all from the top, only (barely from the bottom and side if I pull off the tire). I was able to confirm where it was coming from, it was a black, plastic outlet about a .5" diameter, with a 2" ring like wall around it, (not sure if the 2" diameter has anything to do with it). Anyways the outlet is pointed just about straight down, and my main problem is, there is no hose anywhere around and I don't know where it's connected to, if anybody could let me know what that's called and where it connects to, that would be great.
Thank you in advance
-Ronnie
MoistCabbage
10-05-13, 10:21 PM
Is this outlet coming out of the firewall?
Ronnie Fierro
10-05-13, 10:23 PM
I don't think so, it's near another rubber coolant hose and a brake line, does that help at all?
rodnok01
10-06-13, 08:52 AM
If it's near(below) the center of car pointing down thats the evap drain pipe, sounds like heater core is leaking inside and draining out the drain hose for condensation.
MoistCabbage
10-06-13, 08:55 AM
That's what I was thinking, but that would be exiting the firewall. But maybe he just can't see the area well.
rodnok01
10-06-13, 08:58 AM
Yea MC, we need a pic or a better description, just cant think of anything in that area that coolant would be pouring from unless a hose just fell slap off.
Ronnie Fierro
10-06-13, 09:28 AM
I'll try to get a picture in a little bit, also when I found it, I just held my finger over it and has someone else pour water into it, in never leaked from anywhere else and the instant I moved it came pouring out, does that help at all? But like I said I'm going to try to get a decent picture now.
Ranger
10-06-13, 10:24 AM
Sounds like the surge tank outlet hose (#3) came off.
http://www.genmotorinfo.com/images/01/9204076M01-025.png
MoistCabbage
10-06-13, 11:24 AM
I always picture the surge tab on the drivers side, because that's where it is on my car. Yeah, could be that.
Ronnie Fierro
10-06-13, 12:11 PM
http://ne1-attach.ymail.com/us.f1208.mail.yahoo.com/ya/securedownload?mid=2_0_0_6_248602_AIxYimIAAGKWUlGI nQZuylIQwng&pid=1&fid=%2540B%2540Bulk&inline=1&cred=SaTSprLLPTCZ.ksbFLFXIR6OfpFX.eSuFbXoggGUdiQx3 Gf5RLScyd2L&ts=1381075709&partner=ymail&sig=fn4dSyPsw.o2xfwJwmqs6w--
This is the best picture I could get but the center of the picture is where it's pouring out.
Ranger
10-06-13, 07:41 PM
I think they keep moving them from side to side just to confuse us.
The link takes me to my Yahoo sign in page. :noidea:
MoistCabbage
10-06-13, 07:52 PM
It was working earlier, I couldn't tell what I was looking at, but the plastic piece pictured had something broken off of it.
Ronnie Fierro
10-13-13, 09:05 PM
Well it was the heater core, just "fixed it" today; bypassed it.
