kimcheejeegae
04-17-05, 02:41 AM
I have an 05 ... and the audio settings will not stick with my radio nor my xm... I've programed EQ1 to my settings.. and it'll stick when i switch to CDs but when i go back to radio or XM... the settings are back to preset: custom, dsp: normal, avc: off... Each time I have to set it to EQ1, Spacious, On.
ugh! What's wrong?
homer403
04-17-05, 02:46 AM
I had the same problem until I went to the FAQ section... it's there. My EQ settings now "stick". Look in the FAQ section.
kimcheejeegae
04-17-05, 02:57 AM
Ahh.. yes.. thank you!!!
homer403
04-17-05, 03:18 AM
I can't sleep so I looked it up...
http://www.cadillacfaq.com/faq/index.html
Click "Radio"
Click "How do I Keep the audio settings,(EQ settings) permanent? (http://www.cadillacfaq.com/faq/answers/radiopreset.html) http://www.cadillacfaq.com/faq/nw-use.gif (http://www.cadillacfaq.com/faq/answers/radiopreset.html)"
Much THANKS--I am having the same problems. I'll give it a try.
Ginnie
after you set the radio station of choice, set the main memory on the door. Then it should do it..
dreamcarc6
04-17-05, 10:49 AM
Nobody reads the manual anymore???
homer403
04-17-05, 10:51 AM
Honestly, the manual wasn't too clear and the dealer was, of course, clueless when I got my V back in November, BUT as usual, I found the solution here in the FAQ section.
