View Full Version : Were Do I Get A V Air Filter
rmrocket
04-15-05, 01:58 PM
THERE WAS A PREVIOUS POST REGARDING THE AIR FILTER FOR THE V. IT INCLUDED THE PART NUMBER FOR GM AIR FILTER. I CAN NOT FIND THE POST REGARDING THIS. CAN SOMEONE HELP
THANKS IN ADVANCE
RICH:yup:
homer403
04-15-05, 02:19 PM
If your getting a new filter, why don't you try the K&N drop in? Here's the part number for the K&N.
33-2649 Product SpecificationsProduct Style: Panel Air Filter
Height: 1.188 in (30 mm)
Outside Length: 10.75 in (273 mm)
Outside Width: 7.375 in (187 mm)
Filter Re-Oiling Amount: 1.21 oz (36 ml)
Inner Wire: No
Top Style: Open
Weight: 1.1 lb (0.5 kg)
Product Box Length: 13.5 in (343 mm)
Product Box Width: 7.75 in (197 mm)
Product Box Height: 1.75 in (44 mm)
homer403
04-15-05, 02:29 PM
I forgot to say the K&N cost $37.24, free shipping I think?
http://tsetruckstuff.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=KNPP and type in 33-2649
CTV-Old-E
04-15-05, 02:37 PM
I heard that the oil in the filters is causing problems with the electronic sensors in the car over time. I know it is an issue in the newer BMW's. Anyone else heard that?
homer403
04-15-05, 02:41 PM
Oh... I forget to tell you... to get free shipping, enter Code: KNE
At $37.24 includes free shipping, that's cheap.
The web site is http://tsetruckstuff.com/Merchant2/...egory_Code=KNPP (http://tsetruckstuff.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=KNPP) and type in 33-2649
benjet
04-15-05, 03:00 PM
IMHO the K&N (air filters) are far more trouble then they are worth.
StealthV
04-15-05, 06:13 PM
THANKS IN ADVANCE
RICH:yup:
Rich, the GM part number for the CTS-V air filter is 25750701, AC Delco part number A1623C.
http://www.cadillacforums.com/forums/attachment.php?attachmentid=7964
dannystang
04-15-05, 07:47 PM
I may have to buy one of these if someone doesn't ship me an intake already...
Hmm who sells Cts-V intakes?
Hmm wonder if they are in stock.
Groo-V
04-16-05, 08:40 AM
IMHO the K&N (air filters) are far more trouble then they are worth. What problems are people having with them? I was just about to order one when I read this.
homer403
04-16-05, 09:02 AM
Primary problems with the K&N are (1) expensive and (2) hassle to clean. But because if we can get them cheap, got mine for $37 shipped, it not expensive for me. Secondly, I don't plan on cleaning mine (see the cleaning instruction http://www.knpowersports.com/clningins.htm) because they last 50,000 to 100,000 miles. I plan on replacing mine at 50,000 miles with a new one. But I will check it from time to time. As for oil in the going into the intake... someone needs to expand here... my friends at Mazda Club and BMW clubs uses the K&N for years and they haven't had this problem. Hope this helps.
StealthV
04-16-05, 10:41 AM
During the cleaning and re-oiling process of the K&N, it is possible to place too much oil on the filter. This "loose" oil, under high engine load, ends up on the delicate MAF sensor wires. This contamination on the MAF wires changes the sensor's calibration, throwing off the air flow measurement into the engine.
If one is concerned about this, pick up some electrical contact cleaner at the autoparts store, remove your MAF and "hose down" its wires once every great while.
benjet
04-16-05, 11:21 AM
1> Many of them come over oiled from the factory, I have seen numerous cases where the TB butterfly was caked up with stuff ~10k after inital installation and that's right out of the box - never been cleaned/re-oiled, they are supposed to be ready to drop in right out of the box (this was not the only part with oil covering it, the oil goes where the air does).
2> Many of them let in too much dirt. In several cases I've done oil analysis ~5k after inital installation of a K&N right out of the box, silicon (dirt which your air filter is there to remove) almost always reads high, causing undo engine wear (changing oil and puting the stock filter back brings the #'s back in line), something I'm (personally) not willing to risk for a replacement air filter. Jim Conforti (BMW master tuner guy) did some similar tests on the amount of dirt they let in and has proven this to be the case for (IIRC) ALL oil gauze type filters on street cars. I have shown this (my results) to K&N whose response is it must be some other factor it's not OUR air filter (whatever).
YMMV
-Ben
http://www.bmwe34.net/E34main/Upgrade/Air_filter.htm
http://mymiata.paladinmicro.com/K&NComments.htm
I used to have more.
