miishmiish
10-10-03, 09:29 PM
I copied and pasted this from some random site. Does anyone know if this is true? Is there a procedure like this for a 1997 caddy deville?
Here it is:
(a way to shut off that stupid "service ride control" light
________________________________________
Okay, first of all, don't try this at home; not for the faint of heart; don't blame me if it breaks; I was not even there at the time. It is always best to repair the car properly, with new parts, when it breaks.
Also, "Incorrect option information in the IPC may cause many different problems". And disabling the warning messages obviously does not fix the system; it just disables the warnings.
On the Allante forum (www.allante.org) I saw a message thread which detailed how to disable the "Service CCR System" message (actually the SDD version that they had on the Allante, but similar problem). Thanks to Russ Peters (peters@attglobal.net) for repeating that message; he thanked phil1@perigee.net who apparently discovered this while trying to turn off the daytime running lights.
Consulting my Helm shop manual (pg 8C1-11 for those of you with the 92 version) I see a similar procedure. I have tried this, and it appears to work. The idea is that you tell the computer you don't have Ride Control, so the computer does not complain that the ride control does not work.
Lo and Hi refer to pushing the Lower fan speed or higher fan speed buttons.
0. Turn the ignition switch to battery (on but not start)
1. Enter diagnostic mode by pushing Off and Warmer together
until the instrument lights stop flashing.
After any codes are displayed, step through the queries as
follows:
2. CCM? Lo
3. IPC? Hi
4. IPC Data? Lo
5. IPC Inputs? Lo
6. IPC Override? Hi
7. IS00 Lo
8. IS45 Lo
9. 001 IS09 Lo (this may say "129 IS09" if you have the heated windshield option)
10. 008 IS08 This is the value we want to change. Press the Warmer and Cooler buttons to increase/decrease. Change this value to 000, which means no CCR. 008 means has Ride Control. This value is actually a sum of options; 008 is normal for north american cars. If you have some other number, just subtract 8
from it to turn off the ride control.
11. Press the Econ and the Front Defrost buttons at the same
time and hold until the 000 IS08 flashes. This takes a few
seconds. This writes the setting to memory.
12. Turn the ignition switch off.
13. Test drive and see if CCR error message appears.
Normally I get the Service CCR message as soon as I back out of the drive. During the test tonight I got it right away. After I turned off the CCR system I never got it. When I turned it back on I got it before I left my block. I think this change has
disabled the CCR system (which was not working anyway) and the related warning message.
Here it is:
follows:
2. CCM? Lo
3. IPC? Hi
4. IPC Data? Lo
5. IPC Inputs? Lo
6. IPC Override? Hi
7. IS00 Lo
8. IS45 Lo
