View Full Version : Head n cam or charged ?
AllDayRay
08-31-13, 09:39 PM
Wanted to know what would u get most power from ? What kind of power do u get
from each one ? How reliable would either one b? And is it possible to do them both what kind of power would that make? Thanks guys ahead of time just trying to find out what way to go for playing around with friends on street and track
AllDayRay
08-31-13, 10:47 PM
No forgot to let you guys know car is a 04
H-town_V
08-31-13, 11:11 PM
This sounds like the title of a weird porno...
Sry I can't help with your question.
RyRidesMotoX
09-01-13, 01:17 AM
The question you have to ask yourself is what you want out of the car. The rear end sucks in the V so I would start wyh a Ford 8.8 rear upgrade at least. I'm going to have my heads machined, fast 102 I take and throttle body (either Nick Williams or FAST), cam and new lifters pushrods and springs, usually valves can just be cleaned up. Then if that isnt good enough I'll just put on a procharger or some kind of forced I induction. I want a car that will pull hard through the upper half. I like to run on road courses. And one course I run on uses about a mile of a NASCAR oval so top end is key. If you are going to daily drive it just put on a Magnuson 112 and enjoy the sweet torque band.
Before you modify any car. You must be honest with yourself about what you are really looking to do with it. That way it will be well built for what you are using it for.
Naf
09-01-13, 02:13 AM
If you want a more controlled and safer power adder, then go heads and cam, later you can add a blower if you didnt get HC heads...
There is a pair of LS6 ported heads on Ebay that are cheap, and toss in a LS9 cam and 1.85 yella terra rockers. Great idle and street manners with decent power. You can also charge it later with less investments for later...
Becker
09-01-13, 09:10 AM
I think if I was going to dump some money in my V I would probably do a nicely built stroker. Fully forged just in case I was going to charge it later, milder heads and cam. but a really nice 500 hp all motor.
But I think thats all a tease if you cant put it to the pavement, so I would probably beef the drivetrain up and do a little suspension before a stroker.
Seems to me the maggie is very popular on the V1's
H-town_V
09-01-13, 04:15 PM
http://houston.craigslist.org/pts/4026584277.html
Is this a good deal and would it be a good setup on a ls6 V? I plan todo headers within the year and will prob buy some ported heads as well. Will the stock ls6 cam support all those mods or does it need to be upgraded to. I had a stock ls7 cam but I sold it for $120.
My other question is can this fast 92 be used with a ls2 TB and would that be better than the wire drive one that's on there.
Naf
09-02-13, 02:18 AM
For almost the same price you can get a NEW 92mm Fast intake and use it with a ported Ls2 TB. this one is too old and the tb wont work with you...
Try and get a LS9 Cam, its almost identical to the LS7 except a little more exhaust duration, and more LSA. Not to mention you can buy it new for $120 vs $300 for the LS7...
rand49er
09-02-13, 07:24 AM
Track: H/C
Street: SC
My $0.02.
H-town_V
09-02-13, 02:41 PM
Yea that's what I told the guy. I offered him $600 just for the intake...I'm waiting to here back from him.
AllDayRay
09-04-13, 09:14 PM
Thanks for you guys input
lollygagger8
09-05-13, 10:23 AM
H/C if you want the same amount of power all the time and heatsoak is not an issue.
S/C is hard to beat when IAT temps can be controlled (meth)
kw3kw
09-13-13, 11:30 PM
Here's a look into my '04. It has a MP112, 90mm TB, Moroso catch can & Derale oil cooler. dyno@ 474whp 431tq. stock cam, no headers just Magnaflow catbacks. Good Luck on your decision.
John R.
brngrhd
09-14-13, 09:38 AM
John R.
Is the t-body worth it? What upper pulley is that?
kw3kw
09-15-13, 10:27 PM
I got 31whp and 20ft/lb tq from the larger TB
The pulley is the one that came with the blower kit (stock)
