View Full Version : headrest removal??????????
brutedog
03-30-05, 09:54 AM
can any one tell me how to remove the headrest on my 02 escalade? i see the front has screws in the bottom should I remove them? thanks:cool:
honda4x4nut
03-30-05, 11:53 AM
To remove the headrests you need to pull the headrest all the way up. There is going to be a plastic square shaped cover where the post enters the seat. On that piece you will see a very small hole. Use a striaghtened paper clip to push into the hole that will push a button in the piece and release the post on that side, then do the other post being sure to hold up the first one so it will not go back down and clip again. Good Luck
