View Full Version : 1999 Caddy Seville Sts
JSONXXX
10-08-03, 05:28 PM
Does Anyone Know If There Is A Way Of Testing The Fuel Pump?
Or A Valve In The Engine Comparment?
I Keep Getting Error P0231 Fuel Pump Feedback Circut Low Voltage. I Replaced The Fuel Pump Relay.the Code Is Still Current
After Being Cleared.
Also C1738:exhaust Solenid Valve Short To Ground
Does Anyone Have A Idea In Which Direction I Should Go?
Any Help Or Advice Would Be
Great!!!
elwesso
10-09-03, 09:05 PM
Without having an FSM, your gonna need to test something on teh actual pump.....
Usually, on a Q, when the pump starts getting noisy, then its going bad.......
JSONXXX
10-10-03, 04:17 PM
you said fsm what is this can you be more specific?
nthanks json
elwesso
10-10-03, 08:09 PM
Factory service manual...... I am not a fan of chiltons or haynes...... Get what the pros use!!
you can get them at www.helminc.com ....... A little pricey, but worth the money...... Dont stoop low and by the cheapo haynes or chiltons!!!!
