: Key chime continues to chime even when key is removed
jimbaxter
08-20-13, 12:34 PM
2006 DTS: Even if the key has been removed from the ignition, the chime continues to chime when the driver door is opened. Any suggestions? I've made sure that headlights aren't on, reset the key fob, and even tried adjusting the volume (FYI Loud is crazy LOUD)
Superjim
08-20-13, 03:52 PM
Sounds like a computer GLITCH...
There is a way to REBOOT all of the electronic modules in the entire car.
Sometimes ( lots of times) that will fix random electrical gremlins.
Remove BOTH battery cables... negative cable FIRST...
Touch both cables together for 5 seconds or so, making sure they have good contact with each other.
This will drain all the capacitors in the system.
While you have the cables off... undo the one bolted to the floor.
Take a little piece of sandpaper and sand the paint away from the attachment point.
It will then have a better ground.
Re-attach the battery cables... negative cable LAST...
You will have to do the window EXPRESS UP learn again and you MAY have to do the memory seat settings again.
Sometimes they will forget the seat settings and sometimes they don't.
Tom1980ny
10-30-13, 06:41 AM
I am having the same problem with my car. If I put the key in and out a few times it would sense the key was gone, but now that is not even working.
TopherS
10-30-13, 11:51 AM
I'm having the opposite problem...I can leave my key in the ignition and no chime. I can get into my car and put the key in the ignition (with the door still open) and no chime. The "lights on" chime works fine, but the "key in ignition" chime has worked only a couple of times since I bought the car (in June)...most times, it doesn't work. Would that reset procedure work for that, as well? And, I'm not sure what you mean by the window express up learn thing...???
Cadillac Cust Svc
10-30-13, 12:40 PM
Hello Tom1980ny,
If this is a concern you would like to work with the dealer towards resolving, please let me know. Contact me via private message and include your full contact information, VIN and current mileage.
Sincerely,
Laura M.
Cadillac Customer Care
Hi TopherS,
If this is something you would like to discuss with your dealer, let me know so I can assist throughout that process. I can be contacted via private message to further discuss your situation.
Laura M.
