View Full Version : Changing water pump on 07 DTS. Did I order all necessary parts?
Rocc4Rocc
08-19-13, 12:18 AM
Noticed coolant leaking from bottom of water pump housing. And my engine seems to overheat while idle. Engine has 180,xxx miles on it, runs strong, and as far as I know the water pump hasn't been replaced. Ordered a bunch of parts and am going to try changing it myself. I got a lot of info from this thread, http://www.cadillacforums.com/forums/cadillac-dts-forum-2006-through-2012/285580-water-pump-replacement-2007-dts.html, and it recommended I change all the parts associated with the pump.
Here is a list of parts I ordered, all are GM OEM:
12559807- Thermostat
3522676- Thermostat seal/ O-ring
251 698- AC Delco Water pump (gmpartsdirect lists the water pump as #12583033, do I have the correct part?.)
12600020- Water pump gasket
251-2027- (x2) water pump gasket
251-2023- (x2) water pump gasket
3535846- Water pump pulley
12588412- Water pump belt
Should I order 12555153- Belt tensioner? Am I forgetting anything? If I were to bring all the parts to a local mechanic how much do you guys think they'll charge?
Tom's Caddy
08-19-13, 09:19 AM
This is a big job, you are missing the crossover gaskets ( 4 of them ). The crossover has to come off to remove the water pump, you must use NEW GASKETS.
1BadCadSTS
08-19-13, 09:26 AM
This is a big job, you are missing the crossover gaskets ( 4 of them ). The crossover has to come of to remove the water pump, you must use NEW GASKETS.
Since when? All other fwd n*s never needed the cover assembly pulled.
Tom's Caddy
08-19-13, 09:39 AM
No more special tool for the water pump is needed anymore as well. 2006-2011 pump is behind crossover. Pump can not be removed without taking off CROSSOVER.
Rocc4Rocc
08-19-13, 11:50 AM
What is the part number for the crossover gasket? Either acdelco#, or gm#. Thanks for your reply.
@Toms Caddy- Also how do you remove the water pump pulley without the tool? If I'm correct, its a pressed on part, and the tool grabs one of the outer threads and pulls it out.
RippyPartsDept
08-19-13, 01:05 PM
your thermostat seal is the old design part number and will not fit right in the recess where it sits in the pump cover housing
use #12574478 ... it is a little bit thicker and will form a good seal (as it should)
Rocc4Rocc
08-20-13, 02:45 PM
Thanks for everyone's feedback. @chris I ordered the new part, thanks. @tomscaddy the water pump gaskets (251-2023, 251-2027) are the crossover gaskets. Looks like I have everything I need.
Tom's Caddy
08-21-13, 01:08 PM
:thumbsup:
