: Help for a friend and his 1999 Catera
Cadillac Catera98
08-18-13, 12:25 AM
Hi all, my friend needs help with her Catera. She say's her that Oxgen Sensor has a problem or is broken and that she can sart the car and drive about 3 miles and the car will die!!!!! I'm thinking a dead battery or so but I could be wrong, may you guys help me so I can help her..
kaustein
08-18-13, 10:44 AM
crankshaft positioning sensor. Very common problem. About a $150.00
Cadillac Catera98
08-18-13, 11:32 AM
Is that why the car is shutting off or is that going to be for the oxygen sensor????
kaustein
08-18-13, 04:53 PM
Could be. I've never had an O2 shut down a car. CPS is a very common problem.
MoistCabbage
08-18-13, 07:54 PM
It's not the o2 sensors.
Take the car to AutoZone and have the codes pulled. Replacing anything before that is just guessing.
retho78
08-18-13, 08:21 PM
It's most likely the crankshaft position sensor and cost about $45 to $50. I had a similar problem about 6 months ago and replaced it and so far no problems. The sensor is located right by the oil filter and the other end goes all the way to the top behind the upper intake (driver's side).
Cadillac Catera98
08-19-13, 06:04 PM
In saying this will be a easy fix for her?????? Because if not she should just get rid of the car...
kaustein
08-19-13, 08:53 PM
Fix it and then get rid of the car! No matter how much you like it or think you are cool driving a caddy, the car is a piece of crap! Seriously!
Cadillac Catera98
08-19-13, 09:09 PM
Who you Who you???? FYI this is not my car. I'm helping a friend, she dose not have the finances to go and get another car and if she did I would not be on here asking for help to fix her car.... She doesn't think she is cool because she drives a Cadillac for your info.
Post edited for inappropriate language. Please be careful.
MoistCabbage
08-20-13, 02:18 AM
In saying this will be a easy fix for her??????Depends on what's wrong with it. If it's the CKP sensors, them yes, pretty easy and cheap.
retho78
08-20-13, 08:31 AM
Yes, it's pretty easy fix and I would say about an hour all together. You may have to cut the old wire where it gets pinched by the oil cooler lines and send the new one around it. Also, add extra aluminium foil (extra heat shield) around the new wire where it gets close to the exhaust pipe.
Cadillac Catera98
08-20-13, 08:15 PM
This is her first car!!!! Her dad got it for her when we was in the 10th grade he paid about 3k for the car with add fees. She only had one problem with the car since she got it which was the transmission 2 years ago and it's been fine every since till now... and she just got to 106,000 miles.
kaustein
08-20-13, 08:28 PM
She is very lucky. The cars are awful. Not just me saying that. Read the post here. If you fixes it, and if it were my daughter, knowing what I know about the car, I'd tell her to get rid of it ASAP.
Cadillac Catera98
08-20-13, 10:37 PM
I know what you are saying.. My dad talked me out of getting a catera, she only putting up with the car till late spring of next year. She just once to it fix to get her from point A-B & C...
kaustein
08-21-13, 02:38 PM
Well again it sounds like the CPS. Make she carries a charged up cell phone and join the Auto Club!
MoistCabbage
08-21-13, 08:10 PM
CPS = Central Power Supply
CranKshaft Position sensor - CKP
Cadillac Catera98
08-21-13, 09:48 PM
Well here are the parts she need's to buy.... and please let me know if they are the wrong parts
1. 2 O2 sensors they are
Bosch - Oxygen Sensor
Part # 16065
2.CranKshaft Position sensor
BWD - Crankshaft Position/Angle Sensor
Part # CSS79
3.Speed Sensor.... now we are lost with this one is there a difference between an ABS Speed Sensor and a Speed Control Sensor????
and each part was found at O'Reilly Auto Parts on O'Reillyautoparts.com
MoistCabbage
08-22-13, 05:23 PM
There is a speed sensor for each wheel (wheel speed sensors), and a vehicle speed sensor (for PCM and speedometer). No such thing as a "speed control sensor".
How do you know the O2 sensors need to be replaced? How do you know there's a speed sensor problem?
Were the codes pulled???
Which codes came up?
Cadillac Catera98
08-22-13, 09:38 PM
I didn't pull any codes her dad did and he stated that the O2 sensors need to be replaced, which I think they might need to be cleaned. I know from the jump that she need with the Crankshaft Position/Angle Sensor because from what I seen it will drive about 3 miles and shut right off..
MoistCabbage
08-22-13, 10:44 PM
O2 sensors can't be cleaned.
Which one threw a code?
Speed sensor???
Without codes, we can't help you.
Cadillac Catera98
08-27-13, 03:16 PM
Speed sensor???
That's the thing MC the car will only go so far before shutting off and now the car wont even start.
MoistCabbage
08-27-13, 06:18 PM
Know anyone you can borrow a scan tool from?
Cadillac Catera98
08-27-13, 10:23 PM
I will see what I can do. But 9 out of 10 I won't find one!!!!!
MoistCabbage
08-27-13, 10:35 PM
Might be time for a tow truck.
Cadillac Catera98
08-28-13, 06:45 PM
Would you know how to find a diagram on how to get to the CPS, or do you know anyone who has a diagram for CPS MC???????????????
MoistCabbage
08-28-13, 07:02 PM
If I remember later, I'll try to find one. But for now, try Googling Catera CKP Sensor.
Cadillac Catera98
08-28-13, 07:12 PM
I have been doing for the last hour, ronnie who fixing the car need's to find out how to get to the CPS MC...
MoistCabbage
08-28-13, 07:19 PM
Have you been googling CPS or CKP? CPS = Central power supply. It's often misused in this forum.
http://www.cadillacforums.com/forums/cadillac-catera-cimarron-forum/67854-98-catera-crankshaft-position-sensor-replacement.html
Cadillac Catera98
08-28-13, 08:14 PM
I was looking under CPS not CKS.. We already use that no help. What he wants to know is how it looks and how to get right to the senor, he looking to get right to it so he can to know what to take off and what not to take off..
MoistCabbage
08-28-13, 08:43 PM
Did you click on the link? It's a step by step on replacement, with pictures.
Cadillac Catera98
08-28-13, 11:38 PM
Yes I clicked on the link... This is what he used to get to the CKP or the CPS whatever it may be, from I was informed on is that he want's to know what he is looking at and what he will be taking apart so he can get to the sensor take it off and replace it.
MoistCabbage
08-28-13, 11:50 PM
Pictures of what has to be removed are in the thread.
If he's wondering what the sensor looks like, just look at the new one. I assume he'll have it when he starts the job. Or find the part online, there are usually pictures.
If he's wondering exactly where it is, follow the wire pictured in the thread. It's visible from under the car, near the oil filter. Held on with one bolt.
There's a diagram here, but not very good:
http://www.justanswer.com/car/1ebv9-site-twice-issue-97.html
Cadillac Catera98
08-29-13, 05:08 PM
Well from what I seen that's pose to be the connector, and to take the CKS off it's on the left rear of the engine block. Now please check me if I am wrong!!!!!
Cadillac Catera98
08-29-13, 10:09 PM
Is a duralast part going to be ok to place on the Cadillac??????
JohnJJO
09-01-13, 06:24 PM
I been usind duralast part in a pass until I start u order over online. I personaly never had a problem with duralast parts in exception of rotors. They will worp in 1 year , even with ceramic brake pads.
Cadillac Catera98
09-01-13, 07:56 PM
Ok, because I know most Cadillac owners use Acldelco parts, and Acdelco on my 01 STS.
What size group is the Catera for a car battery???
retho78
09-02-13, 11:44 AM
did you replace the crankshaft position sensor?
Cadillac Catera98
09-02-13, 02:20 PM
Our guy is doing that now!!!! he's putting every part back in its place..
Cadillac Catera98
09-03-13, 10:22 AM
The bad part about this now, it's a dead battery in the car...
Cadillac Catera98
09-03-13, 06:26 PM
Yes we replaced the CSP & just placed a new battery in the car, but with the CSP on and the battery in the catera it's starting to miss fire. We have no clue why it's miss fire??? any help please
[QUOTE=MoistCabbage;10839810]Pictures of what has to be removed are in the thread.
we replaced the CSP & just placed a new battery in the car MC, but with the CSP on and the battery in the catera it's starting to miss fire. We have no clue why it's miss fire??? Now we can't even get the car to a code reader.
retho78
09-04-13, 12:29 AM
probably he misplaced something or maybe some wire is not connected.
Another possibility might be bad coils or have to relearn throttle body in case he removed it or maybe a vacuum leak somewhere.
also, try unplugging the Mass airflow sensor and see what it does. It could be a MAS sensor too.
Cadillac Catera98
09-04-13, 07:30 PM
This is what is planed for Saturday... We are gong to replace the coil packs and the spark plugs, do you or anyone else has an idea of brand of spark plugs and coils we should go and get??? I have in mind of getting (Autolite Single Platinum Spark Plugs and BWD Ignition Coil & BWD Ignition Control Module) We are going to pick up the parts Friday....
kaustein
09-04-13, 07:51 PM
I hope that you figure it out. This way you will have time for the next problem. They always come in "sixes."
Cadillac Catera98
09-04-13, 08:28 PM
LOL!!! I hope we do, because parts are free because of the company her dad works for but its going to be the labor that kills us when & if something goes wrong.
retho78
09-05-13, 11:34 PM
maybe get bosch plugs (4 prong) style
Cadillac Catera98
09-06-13, 06:30 PM
I have one question because my dad went and bought spark plugs that I never heard of or even seen before.
Denso PK20TT Platinum TT Spark Plug.
I mean are they good plugs to place in the Catera?????????
bobbyc67
09-08-13, 06:04 PM
Sounds more like a fuel filter. Not really enough information. Does it start right back up or do you have to wait a few minutes ? Instant shut off or does it sputter first ? I have not seen an O2 sensor shut one down 3 miles after starting. Usually you notice it runs rough, drinks gas, or a couple of other things, but usually not a shut down problem.
As for it being a battery, does it go dead ? Lights still work ? still turn over ? Need to know things like these to diagnose the problem.
MoistCabbage
09-08-13, 08:28 PM
Duralast parts are ABSOLUTE GARBAGE!
Don't bother with the multi electrode plugs, they're a gimmick. The spark can only jump to ONE at a time.
A fuel filter will not cause stalling after several minutes of driving.
If you're trying to fix this car cheap, throwing parts at it is NOT the way to do it.
Have the basics been checked when the problem occurs? Spark and fuel pressure?
AGAIN... What CODES is the car throwing?
What is a "MAS sensor"?
Cadillac Catera98
09-09-13, 11:25 PM
I had a feeling duralast aren't good.
And no MC we are not just throwing parts at this car to be cheap, we are replacing parts that could be the issue. How we changed the CKS and placed a new battery in the car. We seen that the car was misfiring after we put the CKS and the battery, now could be the issue to the misfiring might be the spark plugs the coils. Which was pose to get done last weekend but the Florida weather stepped in and it didn't get done. So tomorrow he is placing the plugs and the coils , next weekend is the fuel pump if that still does nothing we are taking the car to Volkswagen dealer because of it being a German car and all.
We can't get the car anywhere if it's misfiring..
MoistCabbage
09-10-13, 02:00 AM
And no MC we are not just throwing parts at this car to be cheap, we are replacing parts that could be the issue.That is the definition of throwing parts at a problem. Replacing things that COULD be the problem.
Repairing is replacing parts that ARE the problem.
How we changed the CKS and placed a new battery in the car.If it needed a battery, it needed a battery, but there was no reason to replace the CKP sensor unless there was a code for it, or it tested bad.
We seen that the car was misfiring after we put the CKS and the battery, now could be the issue to the misfiring might be the spark plugs the coils. Which was pose to get done last weekend but the Florida weather stepped in and it didn't get done. So tomorrow he is placing the plugs and the coilsPlugs are a maintenence item, coils are not. Why are they being replaced, did they test bad? All of them? One? A few? Has anyone even checked which cylinder is misfiring?
next weekend is the fuel pumpWhat? Why? Was the fuel pressure tested? Is it low?
if that still does nothing we are taking the car to Volkswagen dealer because of it being a German car and all.The fact that a sister car of the Catera is sold under a German nameplate does not make the car German. Besides that, Opel is a GM owned company anyway, and the engine is built in England... Even if the car was German, taking it to a Volkswagen dealer accomplishes nothing. There are no German voodoo doctors in the shop, just techs, with experience working on, and shop manuals for cars that are completely different from a Catera.
So after this mechanic...no... After this parts changer replaces something, and it doesn't solve the problem, is he giving your friend their money back before he tries something else?
kaustein
09-10-13, 11:40 AM
From experience, Caddy dealers don't like working on the car. Some will give you outrageous quotes with the hope that you will go elsewhere.
atikovi
09-10-13, 05:39 PM
That's like taking a Peugeot to a Cadillac dealer to work on because Cadillac was named after a French dude.
Cadillac Catera98
09-10-13, 05:45 PM
So here is an update from what I seen and know...
So the coils and plugs was changed, the coils and plugs that was in the car was bad I mean the worst.
So come to find out its the fuel pump that's not pumping, because we pumped gas into the cooperator it cranked right up for a few seconds and right back off. Now we just need a fuel pump and we have a running car, after that off to a shop for the basic fluid changes and the A/C service. That's till something else happens!!!
Cadillac Catera98
09-10-13, 10:55 PM
Any ideas where we can get a fuel pump, because I would like to look around before we go and buy the (Bosch Electrical Fuel Pump part#69500) which is $319.99 at Advance Auto parts????????????/
MoistCabbage
09-10-13, 11:02 PM
www.rockauto.com
Cadillac Catera98
09-11-13, 02:15 PM
What should I buy with the fuel pump???? Because I don't want to get the pump and end up needing something else. I will need the fuel sender to the pump right or can we go without it?????
MoistCabbage
09-12-13, 12:42 AM
I would get the pump/level sender assembly. You don't want to have to drop the tank again when that fails.
The only other thing you might need is the lock ring if it's rusted.
Cadillac Catera98
09-12-13, 12:17 PM
143761 is this what I need or
or this what we need
143769
atikovi
09-12-13, 04:10 PM
Depends on what you want. The second one is included in the first one.
MoistCabbage
09-12-13, 05:40 PM
Just get the Airtex with the strainer.
Cadillac Catera98
09-12-13, 06:07 PM
143938
Does anyone know where I can go and pick those two rubber hose from the two right at the front of the engine, because no one part store seems to have them anymore. The right hose has cracked and we need that part. Went to Massey Cadillac in Orlando and was able to get the right hose, but not the left because GM has discontinued the part..
MoistCabbage
09-12-13, 10:15 PM
You mean the intake ducting? If they're no longer available, you'll have to find them used. Salvage yard or online.
Cadillac Catera98
09-12-13, 11:14 PM
Is that what they are called!!! Been trying to think of the name all day.
We plan on buying the fuel pump from 1A Auto here is the link.
http://www.1aauto.com/1A/fuel-pump/Cadillac/Catera/1AFPU00369/662912-1999?utm_campaign=gb_csv_br&utm_content=FPU&gclid=CP7k8Z72xrkCFevm7AodT3IAqA
retho78
09-13-13, 12:42 AM
Just use some gasket sealer or something similar to seal the crack. I have used the sealer when there are crack around plastic hoses and hard to find vacuum line parts, so far no problems and works great.
Also, I have the right side plastic intake ducting which I pulled for the junk yard few months ago. I'm going to the junk yard again this weekend and if you are still looking for that plastic ducting let me know by Saturday afternoon so I can look around and if it's there I can get it for you.
Thanks.
Cadillac Catera98
09-13-13, 02:13 PM
Thanks.
Thanks for your help, but we bought the right intake ducting from GM it had to be special ordered. But come to take a look at the left ducting early today nothing seems to be wrong with it. But thanks for your help retho78
Cadillac Catera98
09-14-13, 06:20 PM
The only issue now is that we have to sit and wait.. Waiting on the Fuel Pump from 1A Auto and the Intake Ducting from Gm which I had to get special order from Massey Cadillac, the parts should be here not latter then Thursday the 19 i'll post photos of everything and an update on the car once we get everything replaced..[COLOR="Silver"]
Cadillac Catera98
09-15-13, 10:14 PM
Guys I have a question, what would happen if we went without the strainer to the fuel pump?????????????????
MoistCabbage
09-16-13, 02:55 AM
All of the debris in the 14 year old tank will get into the pump, lines, and injectors.
Cadillac Catera98
09-24-13, 06:03 PM
Un huh I see.. I have a question we are having someone replace the fuel pump, Our guy was going to charge us $80 but he is acting like an ass and he doesn't want to do the job anymore. So I have been looking around for an MOBILE MECHANIC and the two guys I have talked to so far want to charge us $200. One of the mechanic said this
"The labor cost to replace the Fuel pump would be $200. This is due to the fact that there's no easy access to the pump itself and the entire fuel tank needs to be dropped to get to it." Please tell me this is true because if it is we will go head and pay the $200 for the replacement if not we will go head and keep looking for someone else.
atikovi
09-24-13, 06:32 PM
If the pump is in the tank and there is no access panel, you have to drop the tank.
Cadillac Catera98
09-24-13, 06:36 PM
The pump is in the tank & yes we know we have to drop the tank to replace the pump.
atikovi
09-24-13, 06:48 PM
Then what was the question? I've dropped the tank on a few cars including a 75 gallon one in my motorhome a few months ago. It's not all that hard. If you're in Orlando, there must be plenty of Spanish guys on Craigslist that would do it for fifty and a 6-pack.
MoistCabbage
09-24-13, 09:09 PM
Mobile mechanic? As in "some guy who works on cars" comes to your house? Good luck with that one...
Cadillac Catera98
09-25-13, 12:25 AM
I know what it is MC... The guy who is always fixing my family cars is a mobile mechanic he just doesn't want to this job...
If I see a Spanish guy where I live they are cutting someone grass or cleaning a house, What my question was would that be the normal price to replace a fuel pump on a cater...
MoistCabbage
09-25-13, 02:30 AM
Well that wasn't offensive to anyone...
"Normal price" is whatever the hourly charge is, times however long the guy takes to do it.
Call a dealer and ask what the "book time" is to replace the pump (which is usually longer than the time it actually takes), and assume someone doing it without a lift is going to take longer.
$200 is just under 2 hours dealer time, which sounds about right to me, but you shouldn't be getting charged dealer money by a guy doing the work in a driveway.
It's cheaper than having to get it towed to a garage, so I wouldn't worry about it anyway. As long as the job is done right.
Cadillac Catera98
09-25-13, 08:22 AM
You right as long as the job is done right.. The two guys I have talked have done jobs for friends and etc..
Cadillac Catera98
09-28-13, 02:15 PM
So here is an update you guys!!!!
The new fuel pump and filter is on the car. We pulled up two codes (P1141: Heated Oxygen Sensor (Bank 1 Sensor 2) Heater Circuit Malfunction & P0727: Engine Speed Signal Circuit Malfunction) But that is not the reason why the car is not starting, from what the guy told us the timing is off and he is sending someone out to rest the timing for us. more to come after we rest the timing.
MoistCabbage
09-29-13, 03:34 AM
The timing is off??? There is no distributor, timing is controlled by the PCM, and not adjustable. Did the "mobile mechanic" tell you this?
P0727 - Engine speed sensor? Anyone know if that refers to the CKP or CMP?
In many cars, the tach and ignition control rely on the CMP sensor. If the PCM has no reference of engine speed/position, it cannot provide spark. This can cause hard/no starting, and stalling.
..........As asked before... Is there spark?
Also, with no reference of engine speed, the fuel pump will only run briefly at key on, but not while cranking. You never answered my question about fuel pressure, so I'll assume nobody bothered checking it, but did anyone even check if the old pump ran at all before replacing it? Does the new one run?? At key on? While cranking?
I asked for codes over and over again. I hope for your sake that I'm wrong about what "engine speed sensor" is referring to, because if I'm right, that may have been the problem all along, and the codes would have told us in the beginning.
Cadillac Catera98
09-29-13, 07:49 AM
I just gave you the only two codes that came up MC, I have no clue if there is spark I will have the guy check when they send someone back out..
MoistCabbage
09-29-13, 08:45 AM
I know you have them in the last post. I've been asking since post #5.
There're other questions in the above post as well that you need to ask this guy.
Cadillac Catera98
09-29-13, 12:02 PM
I know you have them in the last post. I've been asking since post #5. There're other questions in the above post as well that you need to ask this guy.
I seen both of your question's & when they seen someone back out I will be asking an having him check everything... If they don't I'm just take it to a shop & see what's up.
Cadillac Catera98
09-29-13, 08:22 PM
[QUOTE=MoistCabbage;11031041]The timing is off??? There is no distributor, timing is controlled by the PCM, and not adjustable. Did the "mobile mechanic" tell you this?
So MC are you saying it could be a speed sensor???? or you are just stating?
MoistCabbage
09-29-13, 09:14 PM
There are several "speed sensors". It's not the vehicle or wheel speed sensors. The code has to be for either the CKP or CMP. There is no other "engine speed sensor" that I'm aware of.
Cadillac Catera98
09-29-13, 10:15 PM
Well it should be the CMP because we just replaced the CKP but then again it can be both, like you said once durlast parts are crap, & that is what we replaced the old CKP with....
MoistCabbage
09-30-13, 04:52 AM
Ok, I found some information on the code on a Saturn forum (similar drivetrain to the Catera).
The code is triggered when the TCM does not receive an engine speed signal from the ECM. That means either a communications issue between the ECM and TCM, or a problem with the CKP sensor, its wiring, or even a faulty ECM.
So... If it were a communications problem between the two modules, the engine would start and drive, but not shift right. A CKP/CKPs
wiring/ECM issue would cause no spark, and no fuel pump operation while cranking.
Check a couple of simple things, you don't need the mechanic:
- Remove the gas cap, and put your ear to the hole. Have a helper turn the key to ON. Do you hear the fuel pump run for a couple of seconds?
- Now have your helper try to start the car. Do you hear the pump running?
-Go to the parts store, and get a spark tester (~$5). Unplug a plug wire from a plug, plug on the tester, clamp it to something metal, have a helper try to start the car. Is there spark?
If there's no spark, and/or the fuel pump doesn't run, replace the DuraCRAP CKP with an AC/Delco one.
Cadillac Catera98
10-04-13, 07:37 PM
Here is an update on my issue..
From unpluging the computer a lot can mess things up and not giving the car enough communications to do anything...'
MC you are right there was an communications issue with the ECM & not it has to be replace our guy said he's going to look to see what he can find and go from there..
MoistCabbage
10-04-13, 08:06 PM
Unplugging the ECU multiple times won't hurt anything. ...More "info" from the portable "mechanic"?
That doesn't mean it's not defective, but before you replace it, check and clean the pins on the connector and the ECU, and check the appropriate wires for continuity.
Cadillac Catera98
10-04-13, 08:31 PM
He did all that, he unplug everything first then cleaned everything... I sat and watch him do everything, he used his truck to try and rest everything took 15mins and that still didn't do anything. Went back and checked everything so the EMC is an issue for now....
MoistCabbage
10-04-13, 08:42 PM
Use his truck to reset something? What?
Anyway. I believe the replacement ECU will have to be programmed to the VIN with a TECH II. Unless you buy one that has been cleared of the previous VIN.
Cadillac Catera98
10-05-13, 10:27 AM
Before he left, he took down the vin as well as the information on the driver-side door with him to look for a ECU. So hopping he finds something if not we might have to buy a new ECU.
What do you think of Cardone Auto parts, I'm asking because that is the part at Advance auto parts and where the company credit line is with...
MoistCabbage
10-05-13, 06:45 PM
Cardone - Depends what kind of part. For the most part, they're good.
There's no such thing as an aftermarket ECM though.
IvoryWhiteCatera
10-10-13, 01:24 AM
This sounds strikingly similar to what happened to my Catera back in April. Honestly, I never looked into it because I just gave up with the car. I would drive it for 15 minutes then it would just stall/shut off. After half an hour I'd be able to start it again, and the same thing happens. Then, while sitting it developed a misfire in cylinder 6 which, I'm guessing, is from bad gas.
MoistCabbage
10-10-13, 01:29 AM
"Bad gas" is excruciatingly hard to find.
IvoryWhiteCatera
10-10-13, 01:33 AM
Old gas.
MoistCabbage
10-10-13, 01:36 AM
If it were old enough to cause a problem, it would be consistent. Not come and go in 15 minute/half hour intervals.
IvoryWhiteCatera
10-10-13, 01:42 AM
Ahhhh dude, I meant the misfire developed a few months ago while sitting. I haven't put in any gas since April, and I'm saying that the misfire may be from months old gas. It has nothing to do with the stalling/shutting off of the car.
atikovi
10-10-13, 08:26 AM
It takes many years for gas to go bad. I have a car in storage that I just took out for the every 2 year emissions inspection. Looking at my records I see I last filled it up in 2006. So with 7 year old gas it still runs fine.
IvoryWhiteCatera
10-10-13, 02:47 PM
Hmm, we learn something new every day. Thanks.
JohnJJO
10-11-13, 08:53 PM
Im not a pro. but 7 years ago a would say gas was different. Alot of chemicals companies started to add to the gas in pass 7 years, to minimize oil in gas so they can produce more to sell. Now gas have expiration date....
MoistCabbage
10-11-13, 09:01 PM
.....What? What oil in gas? Where did you get that little tidbit of information???
Anyway.. In 2003, my '91 Accord was totaled. It sat in a friends yard until 2 years ago, at which point I moved it to a garage on my street. It started right up after 8 years of sitting, with the same gas in the tank, and no stabilizer.
A couple of years ago, my Seville was not drivable for 364 days. After the engine was replaced, it started and ran fine on the whole half tank of year old gas.
Gas that is several months old, is perfectly usable.
Cadillac Catera98
11-29-13, 12:54 AM
Hi to all,
I haven't been on the forums for about a month now, because a little something in the family issue all of your help has still been useful & I have been using it to the best of my knowledge.
But here is a little update & hopping I can have an incite of what to do, come to find out it was never the fuel pump is was the computer to the car which had burned out jumping the car with a dead battery so I was told.
Cadillac Catera98
12-02-13, 08:56 PM
High
