: outside right rear view mirror
gevinsky
08-14-13, 06:40 PM
when i insert the ignition key My right hand mirror goes back to factory settings. i reset it following all instructions will work for few times then out of clear blue sky will go back to factory settings HELP
the cadillac man
08-15-13, 01:06 AM
The memory seat function is the cause try pressing and holding the coresponding driver button for the remote you use(1or2) till you hear a double beep
If that doesn't fix it there are two choices
One replace the mirror
Two disable the memory mirror function
