ccclarke
03-20-05, 03:09 PM
My girlfriend's 2002 STS has had several intermittent electrical faults since she bought the car (used) six months ago. Otherwise, it's a fine car. Being an electrical person, I didn't worry since the car is still under warranty, but I was curious how it could continue to develop so many new faults. The battery died this weekend, so I decided to do a little look-see for myself before it went back in to the shop for --you guessed it, another flaky electrical problem. I suspected a loose battery connection. The battery relay positive connection was tight, so I pulled up the back seat to check the battery. Underneath was a light film that looked like sand. There wasn't any obvious corrosion on the terminals. When I twisted the positive terminal, it broke right off the battery! Looking straight down, I could see pavement beneath the battery! Turns out, the battery had been slowly leaking acid, and the sandy residue was what used to be the floorpan under the battery.
My next-door neighbor dates the local Cadillac service manager, and luckily he was over there. Before I even finished telling him what the symptoms were, he smiled and said, "Battery eat through the floorpan?" He's seen this many times, and says there's a TSB out regarding the problem with a kit to repair the floorpan and replace the battery cable to the engine compartment.
--About a 5-day job and $1100 if out of warranty.
Forewarned is forearmed. Pull your rear seat up and inspect the area under the battery for any signs of corrosion --especially if you're getting close to the end of the warranty expiration. Check the battery terminals where the screw attaches to the battery case for any sulfuric acid seepage where the case and threaded insert for the screw mate.
I did a little TSB reasearch and here's what I came up with--
TSB#: 04-08-61-001 Feb 2004 "Body- Floor Pan Corrosion in Battery Compartment".
