: Differential Bushing $20 DIY option (with pics)
1990Z51
08-13-13, 01:06 PM
Here is a description of how to replace the front differential bushing with an Energy Suspension 3.2125R 1-3/4" OD Rear Frame Shackle for Chevy Truck. Cost is about $20 (amazon). This is very easy and the fit is great. The only drawback it removing the exhaust if you live in the rust-belt
This was described here without pics http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-general/282041-differential-bushing-16-diy-option.html
... so here is a version with pics!!
Take off the exhaust
135930
Remove two rear differential bushing bolts. The bolts do not come all the way out and they do NOT need to.
135938
Remove the front bolt and nut (be careful, you need to support the differential with a jack stand) The differential will drop down enough to service the front bushing
135954
This is what came out of the front bushing (the outer cage stays in place - no need to try and press it out)
135962
1990Z51
08-13-13, 01:10 PM
Next you need to cut the new bushing down so it is 2.5" overall in length. I took 1/2" off one of the halves to get the correct length.
135970
135978
You also need to cut the center insert down as well.
135986
1990Z51
08-13-13, 01:14 PM
Then you just place the bushing in and bolt everything back together!
135994
136002
odla
09-18-13, 12:47 AM
How is this holding up so far?
jims_ctsv
12-23-13, 05:32 PM
Does anyone know if this actually works?
onebadcadi
03-13-14, 11:25 PM
I just did this . And it was easy. And the results are amazing . Reduced wheelhop. Way stiffer. When you order the bushings it comes with two. So I have a spare. I found out the best way to get the old bushing out was a slide hammer.
http://i1330.photobucket.com/albums/w566/liftedduramax02/Mobile%20Uploads/20140313_181342_zpslmplbskd.jpg (http://s1330.photobucket.com/user/liftedduramax02/media/Mobile%20Uploads/20140313_181342_zpslmplbskd.jpg.html)
nikdsctsv
03-14-14, 10:53 AM
seems too me that 50$ for a revshift or creative steel bushing would be worth the hassle of saving 30$. May be just me.
Chirpin4th
05-12-14, 10:05 PM
I know this is old, BUT... to anyone who has done this, are you leaving in the metal sleeve before installing the new bushing?
Chirpin4th
05-13-14, 08:35 AM
Nvr mind.
The info I was looking for was in the first post.
Thanks
Twitch
05-14-14, 09:29 AM
Actually the fact that you don't need to remove the sleeve means you can do it without renting special tools.
I'm wondering about the added diff whine with this bushing.
coltboostin
06-15-14, 01:12 AM
BINGO!
Worth the price of admission right there.
AAIIIC
06-15-14, 10:31 AM
And having the sleeve still in there means there's less bushing material. It's probably only a marginal difference, but it'll be a bit more firm than the bushings that remove the sleeve.
AFAIK, Energy Suspension uses poly with a durometer that's in the same ballpark as the other bushings that are out there, so it should have the same impact on NVH.
SashafromTO
02-05-15, 12:12 AM
Found this thread as I think I may be due for a replacement in the near future. Like the idea of not having to struggle with removing the sleeve from the old bushing.
Wondering how the long-term results are for this DIY bushing. Also, wondering if this bushing adds differential noise into the interior like some of the others?
AAIIIC
02-05-15, 02:20 PM
Any time you replace a squishy rubber bushing with a firmer poly bushing, you're going to introduce more NVH. How much more noise, and whether it's objectionable or not, will vary from car to car and from person to person. And if your stock bushing is totally shot (as many folks have seen), you might gain a bit of gear noise being transmitted into the cabin, but lose some driveline lash/clunk noises, so the overall effect can be a positive.
sarg
04-01-15, 12:43 AM
Any updates for longevity?
WesH8398
04-01-15, 06:38 PM
Old thread revival!! Yay! I'd forgotten about wanting to do this, but now it's back on my list :) Be interested to hear any reports back on how it holds up too. I wonder if this would be at all possible with the exhaust system still in place...?
EDIT: Also, I see they have a "black" version that is the same durometer, etc, except it's Graphite Impregnated in order to help self-lubricate (wait a second... can we 'graphite impregnate'... nevermind). Would there be any advantage or disadvantage to this for the application that we're using it in (front diff bushing)?
From their site: How are these two colors different?
The only difference between the red and black parts is that most Black Energy Suspension parts are Graphite Impregnated. This serves to help self lubricate the bushings. The Red parts do not have this characteristic. Aside from the actual color and the lack of being Graphite Impregnated - the red parts are essentially the same as the black.
Lathedog
06-02-15, 11:35 AM
No need for lubrication. This doesn't move
Lathedog
06-05-15, 05:46 PM
Starting to install these in mine tonite..
WesH8398
06-05-15, 06:57 PM
Starting to install these in mine tonite.. Let me know how it goes, and what (if any) difference it makes!
Lathedog
06-05-15, 11:02 PM
All done.It really wasn't too bad.My exhaust is stainless so came apart easy.Yes you have to drop the exhaust.. I have a machine shop so I turned the bushings to length but you could hacksaw them.Probably had about a hour and half in doing it.
I never drove the car before so I can't compare the bushings.The bushing in it was replaced at one time.It wasn't shot but when I layed under it and lifted on the nose of the rearend it moved up and down.I installed the new one and it doesn't move now.I imagine it will be fine. Jim
Pic or it didn't happen. Lol. http://img.photobucket.com/albums/v24/ikimjing/Mobile%20Uploads/1433556481_zps2fa221e4.jpg (http://smg.photobucket.com/user/ikimjing/media/Mobile%20Uploads/1433556481_zps2fa221e4.jpg.html)
WesH8398
06-06-15, 04:51 PM
Good to hear. I thought I read that you don't have to drop the exhaust, but that hopefully wont be a big deal anyway. Another thing to add to the Caddy to do list.
TheAce
06-11-15, 08:40 PM
It would be nice if the OP came back around (been 3 years since install?) and updated on this bushing's longevity....
Orrah
03-01-16, 08:53 AM
Can you see the rear diff bushings without removing the exhaust? I'm going to look at one this weekend, possibly purchase, I'd like to inspect it.
darkman
03-01-16, 11:27 AM
I don't think you see the OEM rear differential bushing well enough for a visual check even with the exhaust removed unless it has failed so badly that the center rubber has come out. You can take a short crow bar and check for lateral movement.
Orrah
03-01-16, 12:31 PM
Is that my best way to test for bushing wear buying a used one w/ 105k on it?
darkman
03-01-16, 01:18 PM
Check for lateral movement is the only way I know to check for a worn differential with the car on the rack if it otherwise passes a visual inspection.
If I were buying a used one w/ 105k on it I would assume it was going to need a front differential bushing, a transmission mount insert (Revshift), and at least one engine mount, unless: (1) the service record indicated these had been replaced more or less recently; (2) a good mechanic had put it a rack and inspected those components; or (3) the car when driven exhibited very little drive-line lag (clunk) other than from a dead stop particularly when moving the direction opposite of that used to bring it to a stop (i.e. stop while moving forward and then back-up from the stop-this maximizes the amount felt lag).
firstsonofsolo
05-29-16, 02:34 AM
Can anyone confirm the overall length for me please? I have read 2.4 inches and 2.5 inches.
Thank you
darkman
05-29-16, 04:16 PM
My UUC replacement, which still lives in my tool box, has an overall length of 2.360 inches.
bjv
09-06-16, 01:25 AM
I just replaced my diff bushing this weekend with the Creative Steel bushing and block. The hard part of the job is removing the old bushing which requires removing all 3 bolts from the differential housing and dropping the exhaust. Unless you fubar the differential CV joint then you have more trouble to deal with.
If this alternate bushing will fit into the old housing so you don't have to remove the old housing, then this changes the job a lot. It may be possible to remove the one bolt, pry the differential down enough to get the old rubber out, leave the metal sleeve in, put in the new rubber, push the differential back up and put the bolt in it. You may be able to do this without even dropping the exhaust if you have thin hands. I can't say for sure because I dropped my exhaust before getting all of the bolts out of the differential. On a good lift with a good variety of tools you might drop the exhaust, drop the driveshaft, chisel out the old bushing and put it all back in about 3 hours. If you don't have to drop the exhaust and driveshaft and remove the old sleeve it would be only half this much time. If you fubar the driveshaft and you don't know my secret for reassembling it you might need another 3 hours. 1.5 hours vs. 6 hours is a big deal. I was beginning to think the better bet would be to pull out the one bolt, drop the differential, and squirt some kind of epoxy putty into the old bushing.
Darcane
12-13-16, 05:59 PM
Not really.
I just got done doing this and tried dropping just the front of the diff. I think the only way it will flex enough is if both rear bushings are shot too. Probably not even then. I'd recommend just following Paul B and 1990Z51's instructions exactly.
Having just did this with basic hand tools in a cramped garage that is utilized more for a storage unit than a workspace, I have a few observations:
It's smart to make sure you have room to get the exhaust out from under the car. It's one piece and rather large. I wasn't smart here...
The three differential mounting screws have a 21mm hex head. I have 19, 20, and 22mm sockets and my largest metric wrench is a 19mm. :( A 13/16" craftsman combination wrench will JUST fit, but won't slip on and off easily. It works, but was very time consuming to pull the rear bolts off. The 13/16" sockets fit too, but deep sockets were too long and shallow too short for the rear screws.
I was expecting the old bushing to put up a fight... it literally fell out with just a small push after the differential was dropped.
I ended up cutting the sleeve a little off my mark with the hacksaw, the part measured 2.47 inches. It fit fine.
I have an extra bushing. It's free to anyone local (Seattle/Tacoma area).
All in all, it's easy even without a well equipped shop.
Tuckin15s
12-19-16, 09:29 AM
I just ordered this bushing and going to give it a shot when I drop the cradle and do all my cradle bushings and coilovers.
