: 79 coupe deville grill
afaia1978
08-13-13, 11:02 AM
i am just looking for some advice on painting the grill off my 79 deville. the original
plating that was on it was peeling off horrible so i stripped it all off. i was wondering
what color i should spray paint it since i can't afford having it chrome plated? not sure what would look best, a chrome looking paint or a silver? anybody got a suggestion?
Reverend Hearse
08-13-13, 12:15 PM
I've got a few extra chrome grilles , 78 and 79
deVille33
08-13-13, 12:49 PM
There is a chrome-like paint you could try. Available from Sperex which doesn't look too bad. It is one of their polyurethane enamels, part number SP525. Mask off the flat silver ( lot of work on that grille ) that was behind the front edge and just spray the front edge of the grill openings. ;)
bigm57ict
08-13-13, 12:55 PM
That sounds like a lot of work if you want it to look factory. Even then, it won't be the same.
I would just try to replace the grill.
cadillac kevin
08-13-13, 01:31 PM
This. You will spend about the same on an original grille as you would (in paint and your time) trying to make yours look factory.
afaia1978
08-13-13, 03:27 PM
i'm not necessarily trying to get the exact factory look. i am on a very and i mean very tight budget and was
just hoping to get some options that have been tried before and would look good. i appreciate the replies
though. the grill has already been stripped down so i don't think the painting would be too much trouble.
just curious, what are you asking for the grills? where are you located?
csbuckn
08-13-13, 06:01 PM
What color is the car? I'd try a cool color like black or the same as the car. If you don't like it, grab another grill. Spray painting chrome is gonna look rough after a year or so, the grill takes too much abuse. Maybe if you put a few coats of chrome on spraying at the right flash time, it may look good.
talismandave
08-13-13, 08:38 PM
You da man!:highfive:
That was the first thing I thought of when I read the question.
Pop up a picture of the car and our panel of experts will consult and come up with the perfect matching or contrasting color as is called for!:grouphug:
Trying for chrome will look cheap not just be cheap! IMHO
BigPoppaD
08-14-13, 11:28 AM
Color match it or if you want to try a fake chrome, use a real glossy black, then the chrome, helps deepen the look a little. But it still will look like a fine silver
