: Grill removal and installation
08-12-13, 07:12 PM
Hey, just hit a deer and broke the grill assembly of my 2005 Escalade. Can anyone tell me how to remove the tore up grill and install a new one?
Mark Edward Morrison
08-12-13, 08:03 PM
Pop your hood and the black plastic piece at the very front will have some little black plastic type plugs. Get a small flat blade screw driver and pop all those out and remove the plastic part that holds the plug in as well. Now remove the large black plastic piece. Next go to your head lights and loosen them by pulling the "L" shaped pins out so you can get to your grill. Should be one bolt by the lever to pop your hood and remove that. Grill should pull right out.
08-12-13, 09:03 PM
Don't forget the 1-10mm bolt that holds the grill in.
