: Removing Trim
vicb
08-12-13, 04:09 PM
My CD changer broke and I just ordered a factory replacement. Is there any trick to removing the trim around the changer to allow access?
the cadillac man
08-12-13, 05:36 PM
I may have already posted the steps but here goes
First put the truck in 1(hold the main brake)
Second tilt the steering wheel as low as it will go
Thrid remove the bezel around the dash(carefully)
Forth remove the bezel around the cd changer(careful as the clock wiring has to be disconnected)
Fifth remove the two screws holding the cd changer and it should slide out unplug and remove
To reinstall just reverse the steps(test before you fully Raison the dash)
