View Full Version : Does anyone use the Paddle Shifters?
longslim
08-11-13, 04:42 PM
Was on a short trip in the Ca mountains going to Big Bear Lake. There was a nice empty stretch of winding uphill road, so I went into manual. Boy was it a difference in performance and the cars ride was firmer. I think using manual change's the car ride it was very quick out of the curves. I'd need more time driving in manual, I was not very smooth changing the gears. It was not as thrilling as those ATS commercial but not bad for this size car. My blood was pumping pretty good when I reach the top :cool2:
kipsts
08-12-13, 05:15 PM
I use the Sport setting frequently with or without the paddles. It makes for much crisper shifts, tighter handling. I use the paddles when I am on curvy and or downhill roads just as I would a manual transmission. It provides more control. :cool:
Bejaip
08-13-13, 07:42 AM
Does switching in to sport mode save on gas?
kipsts
08-13-13, 08:26 AM
Does switching in to sport mode save on gas? I don't know why it would. Most of the time I am in Sport Mode I am driving more 'enthusiastically.' :)
Bejaip
08-13-13, 11:39 AM
So to go in to sport mode just go to manual. When do you know to use the paddle shifters.
kipsts
08-13-13, 11:49 AM
Any time you would like to use them. I do it when I would like more engine braking going into curves or down hill. If you use them, treat them them the same way you would if you were driving a manual car- listen to the engine for appropriate shift points and/or rely on the tac. I use Sport with or without the paddles when I want more a 'spirited' driving experience. :cool2:
Bejaip
08-13-13, 12:02 PM
So you can use the knob instead of the paddles?
kipsts
08-13-13, 12:05 PM
So you can use the knob instead of the paddles? You can use the 'knob' to put the transmission into Sport mode. You need to use the paddles if you want to control the shifts after putting it in Sport mode.:cool2:
Bejaip
08-13-13, 04:48 PM
could you really damage the vehicle if you do not know what you are doing?
kipsts
08-13-13, 04:52 PM
could you really damage the vehicle if you do not know what you are doing? Certainly not by just putting it in Sport and leaving it there. It would probably lower your mpg while upping your spg (smiles per gallon). On the other hand, putting it in Sport and attempting to 'force' shifts I believe is protected by the CPU initiating a fuel cut out to prevent over-revving the engine. :cool2:
TomD1951
08-13-13, 08:02 PM
I have thought about using the paddles but I am too lazy, just like to set back and enjoy the ride of my XTS.
kipsts
08-13-13, 08:04 PM
I have thought about using the paddles but I am too lazy, just like to set back and enjoy the ride of my XTS. That's the beauty of the option! :cool:
CDN XTS
08-13-13, 10:20 PM
Used it to-day in the Mountains between Denver and Montrosa. ACC doesn't downshift even when following a slow car downhill. It correctly slows down but uses only the brakes, so both uphill when passing I used the paddles and of course also downhill into a lower gear thus also using the engine for braking. Worked great BTW, even in the mountains the fuel usage is great. Filled up in Downtown Denver and again in Montrosa, 282.6 miles increasing net altitude by 584 feet, crossing lots of passes, two over 11,000 feet (went off the I 70 shorty before Vail and took local roads from there) Sometimes briefly really hitting it to pass another car on the two lane highways with those many curves. It has all the power I need. Average speed 53.3 mph. Would you believe MPG was 29.3 on this trip through the high mountains. Manual calculation 29.3829 MPG. "Silverbaby", my XTS Platinum behaved beautifully, holding the road in the curves like a racing car and no increase in water temp. either. On-Star reception on calls to my wife was rather poor but considering the location, I guess that is to be expected. Had a great day, beautiful scenery - stopped quite often - and great driving, reminding me of my many drives in the Alps and Western Canada. Kipsts, we should consider taking a photo of your Silverfox and my Silverbaby together and posting it on the Forum. Will have to clean all the bugs off when getting into Vegas. LOL.
kipsts
08-13-13, 10:37 PM
Used it to-day in the Mountains between Denver and Montrosa. ACC doesn't downshift even when following a slow car downhill. It correctly slows down but uses only the brakes, so both uphill when passing I used the paddles and of course also downhill into a lower gear thus also using the engine for braking. Worked great BTW, even in the mountains the fuel usage is great. Filled up in Downtown Denver and again in Montrosa, 282.6 miles increasing net altitude by 584 feet, crossing lots of passes, two over 11,000 feet (went off the I 70 shorty before Vail and took local roads from there) Sometimes briefly really hitting it to pass another car on the two lane highways with those many curves. It has all the power I need. Average speed 53.3 mph. Would you believe MPG was 29.3 on this trip through the high mountains. Manual calculation 29.3829 MPG. "Silverbaby", my XTS Platinum behaved beautifully, holding the road in the curves like a racing car and no increase in water temp. either. On-Star reception on calls to my wife was rather poor but considering the location, I guess that is to be expected. Had a great day, beautiful scenery - stopped quite often - and great driving, reminding me of my many drives in the Alps and Western Canada. Kipsts, we should consider taking a photo of your and my Silverbaby together and posting it on the Forum. Will have to clean all the bugs off when getting into Vegas. LOL. Wow, sounds like a really spectacular drive!!! Impressive mpg as well. We'll both have to wash off the bugs for the picture- mine coming back from Pebble Beach. We will work it out and get that picture to post for sure. Hum, SilverFox and Silverbaby :cool2:
CDN XTS
08-14-13, 09:41 PM
Didn't do as good to-day from Montrose to Cortez only 25.7 mpg at average speed of 39.5 for the 157 mile trip, but that scenery and the drive up on US 550 to over 11,000 (more than once), down to Silverton at 9318 elevation and further down to Durango was something else, particularly going up from the north. Can totally compare to the Alps as to switch-backs. Every place I could stop I did, Spent so much time stopping that a young Lady passed me a few times on her bicycle. WOW, couldn't do that anymore on such grades for miles and miles. And then the up-lane was on the valley side and no shoulders. I would be dizzy just standing there never mind biking with cars and the odd 18 wheeler passing. Used the paddles but not pushing it today. I bet some cars behind me must have though my brake lights didn't work as the lower gear kept the car at a save speed around switch backs without touching the brakes. Silverton has changed - too many shops - from the last time I was there some 20 years ago vie the train from Durango. But driving an XTS over those high passes is something else. Also went into the impressive Mesa Verde Park so I stopped well short to-day of my goal and will have a long ride tomorrow.
kipsts
08-15-13, 12:46 AM
Didn't do as good to-day from Montrose to Cortez only 25.7 mpg at average speed of 39.5 for the 157 mile trip, but that scenery and the drive up on US 550 to over 11,000 (more than once), down to Silverton at 9318 elevation and further down to Durango was something else, particularly going up from the north. Can totally compare to the Alps as to switch-backs. Every place I could stop I did, Spent so much time stopping that a young Lady passed me a few times on her bicycle. WOW, couldn't do that anymore on such grades for miles and miles. And then the up-lane was on the valley side and no shoulders. I would be dizzy just standing there never mind biking with cars and the odd 18 wheeler passing. Used the paddles but not pushing it today. I bet some cars behind me must have though my brake lights didn't work as the lower gear kept the car at a save speed around switch backs without touching the brakes. Silverton has changed - too many shops - from the last time I was there some 20 years ago vie the train from Durango. But driving an XTS over those high passes is something else. Also went into the impressive Mesa Verde Park so I stopped well short to-day of my goal and will have a long ride tomorrow. Thanks for the continuing update! Sounds to me like you are doing it right- stopping and smelling the roses so to speak:cool: Since I know you spend a lot of time biking as well, that is quite a tribute to the young Lady on the bike. :cool2:
