: 2003 Escalade Stuttering
Importz71
08-08-13, 09:36 AM
I'm trying to figure out why my 03 Escalade 6.0l is stuttering, I was backing out of garage and it was idling rough under 1000rpm and then tried to go in drive and it stuttered a bit.
I put it in neutral and revved it up a bit and after a couple tries it revved up. I drove away and every once in a while it stuttered hard.
Any ideas? Any suggestions would be great.
Thanks!
Jophusp
08-08-13, 10:10 AM
Did you get a "Reduced Engine Power Warning"?
Importz71
08-08-13, 10:12 AM
No warnings at all have shown. I didn't drive it today for fear of damaging something but will drive it around town tonight.
the cadillac man
08-08-13, 10:36 AM
Clean the throttle body before you drive it again and see if that makes a difference
Importz71
08-09-13, 10:52 AM
Pulled the codes and PP171B & P0174B fuel system lean banks 1 and 2. I'm just guessing but possible intake gaskets?
the cadillac man
08-09-13, 03:46 PM
Lean means fuel issues most likely in the fuel system and line
dkozloski
08-09-13, 05:00 PM
Intake air leaks. Spray around the intake with starting fluid while the engine is running to find hidden leaks. Be careful. Your hair and eyebrows will grow back out in a couple of weeks.
the cadillac man
08-09-13, 06:20 PM
I laughed my head off when I read that but you are correct about the ops issue
