: Almost blowing engine
Txao1051
08-04-13, 10:01 PM
This is going to sound bad but here goes nothing. When I floor the gas pedal I am hitting about 5800-5900 Rpms... I let off the gas to shift. If I didn't it would probably redline is this common? I have the 05 ext
wesyder
08-05-13, 01:59 AM
If u stay in it it should shift, if it goes against the rev limiter you my friend have a problem
the cadillac man
08-05-13, 02:31 AM
I have done that before and as long as the rev limiter doesn't kick in(which it will) then don't worry
I have done it more then once so I wouldn't worry
Txao1051
08-05-13, 02:38 PM
So what do I do when it hits the rev limiter? Because you said it will hit it.
the cadillac man
08-05-13, 04:08 PM
If it in park and you do then the rev limiter will kick in but if it is in gear then the speed limiter would kick in at a certain speed
I have yet to hit either
Jophusp
08-05-13, 07:27 PM
I have hit 5900rpm in mine as well. nothing to worry about unless it does not shift after that. JMO.
bigirb2002
08-05-13, 09:13 PM
These stock lq9 engines are safe on stock internals to 6200rpm. U won't hit that anyway unless ur tuned and raise the limit
