: Door handle replacement
Ewest
08-02-13, 08:16 PM
I removed the old drivers door handle that was peeling on my 2005 sts but it was riveted on. The new handle looks like i have to use screws to install it. Has anyone done this?
curtc
08-02-13, 09:26 PM
The factory repair calls for drilling out the rivet and fastening the replacement with a screw...You got it right!
I used aluminum metal repair tape to cover my peeling seam.
Ewest
08-03-13, 08:41 AM
Mine was way to bad for tape so I got a new one. It would have been nice if GM would have included the screws with the handle.
Ludacrisvp
08-03-13, 10:58 AM
Interior - Chrome Peeling Off Of Interior Door Handles
TECHNICAL
Bulletin No.: 06-08-110-004B
Date: March 04, 2009
Subject: Chrome Finish Peeling Off Inside Door Handles (Replace Handles)
Models: 2005-2009 Cadillac STS
Condition: Some customers may comment on the chrome finish coming off the inside door handles.
Correction:
1. Remove the door trim panel.
2. Drill the tops off the two heat stakes with an 8 mm (1/4 in) drill and remove the handle from the door trim panel.
3. Install the new door handle with new M6.5 self-cutting speed nuts obtained locally.
4. Reinstall the door trim panel.
Ewest
08-03-13, 08:43 PM
I didn't know that was how to attach it so I just used screws and flat washers. It worked
ddalder
08-04-13, 03:57 PM
When I replaced mine, I purchased the nuts GM specified in the parts listing. These were a waste of time because they were far too small to thread onto the post (even though they came packaged with the correct/specified part number on the bag). I ended up melting down the plastic posts in the same manner as the handle originally installed on the door panel.
Ewest
08-04-13, 09:16 PM
Great job. What I did was cut off some of the posts with a Dremel tool because they were too long. Then I used large washers and screws. Oh well it probably is better like you said than what G M suggested.
CSM1988
05-07-17, 07:51 PM
Crutc said that Factory Repair said how replacement door handles should be installed. Does anyone know if there is a video showing this process? I would also like to know if anyone knows if both front doors are done the same way.
dkozloski
05-07-17, 10:58 PM
I had one handle replace by the dealer and it was worse than the original. I used aluminum mechanical tape on the next two.
musab302
05-08-17, 09:18 PM
I just bough interior door handels online for a good price.. i wish i red this post earlier.. seems like a husstle to install!
