View Full Version : Please HELP with my "shaking at 60 mph" issue
kadylac1
07-31-13, 03:21 AM
131290
I purchased my 2008 DTS in September of 2012, so I took my DTS to the Cadillac dealer for an oil change on 11/19/12. The dealer reported NO major issues and the car was running great. I went back to the Cadillac dealer for another oil change on 2/25/13, but on my way home (from the dealer) I noticed that my DTS would start shaking when my speed would hit 60 mph. The passenger seat would shake pretty bad, but the shaking would stop once I hit 70 mph. This lasted 2 weeks and then no more shaking. I thought nothing of it, so on 5/18/13 I installed a brand-new set of 22-inch wheels. The ride was amazing, so I took my DTS on a couple of trips from San Diego, CA to Los Angeles, CA and I had no issues. I went back to the Cadillac dealer on 6/24/13 for another oil change, but they found some issues this time around. The Service Advisor said that my Top Engine Mount was cracked (a $180 repair) and that there was slight movement in my Wheel Bearing (a $650 repair). On my drive home from the dealer, I noticed that the "shaking at 60 mph" issue had returned. Everything is fine once I hit 70 mph, but it's getting annoying now. I've seen some previous posts that suggest the "shaking at 60 mph" issue could be fixed by getting a front-end alignment or getting the wheels balanced. Any help or advice on fixing my "shaking at 60 mph" issue would be greatly appreciated. Thanks.
BIGDADDYCADDY07
07-31-13, 05:54 AM
i had the same issue go with the wheel balancing that should fix your 60 mph shake have all 4 checked take it to somebody that can handle 22 inch rims the dlr maybe able to do it
bwv565
07-31-13, 12:01 PM
If possible, find someone who does Road Force Balancing (not all mechanics/dealerships have that capability). It's not expensive and makes a world of difference.
NICE car, btw! :)
kadylac1
07-31-13, 12:05 PM
Thanks BigDaddyCaddy07, I'm going to get some wheel balancing prices from the dealer and a couple of wheel shops in the area.
Thanks bwv565, I will definitely ask for Road Force balancing now.
Cadillac Cust Svc
07-31-13, 03:49 PM
131290
Hello kadylac1,
Nice picture of your Caddy! I apologize for the shaking issue you are experiencing with your DTS at 60 mph. I see other members have offered their advice on your situation. Let me know what you plan on doing; if you are going to have the dealer diagnose your issue and repair. I can be contacted via private message to further discuss any concerns or questions.
Regards,
Laura M.
Cadillac Customer Care
billbill1
08-13-13, 05:23 PM
Had a shaking at around 60-65, when I bought my 2006, with 76K.
Hardest part was to get someone at the dealer to feel it with me.
I stuck it out with several test drives, and swapping tires & wheels with another car.
Final fix was, lower motor mount replacement, and a set of Michelin "SAM'S" tires.
Haven't had a problem since, 30K miles. Have had to watch balance "close", tire looses a
weight and I'm shaking again. Watch those motor mounts !!
