: XTS Platinum 20" wheels
r34220
07-29-13, 04:05 PM
Do these wheels have a coating? I am trying to determine if they can be polished with metal polish.
130857
ldfult
07-30-13, 08:29 AM
I believe they are coated and would not use a metal polish. One might want to use a wax on them, but soap and water should clean them up.
kipsts
08-01-13, 05:46 PM
I believe they are coated and would not use a metal polish. One might want to use a wax on them, but soap and water should clean them up. I agree. I washed SilverFox (Platinum) yesterday and was amazed at how great the wheels still look almost a year later. All I have done is hand wash them with the same soap and water I use on the body along with a sponge or mircofiber cloth. :cool2:
BEarle
08-01-13, 08:13 PM
<img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=130857"/>
Your car looks nasty in your pic! I love the under glow in the grill! Upload some more pics!
r34220
08-02-13, 12:35 AM
My Pleasure !
132050
132058
132066
132074
joesboat
08-02-13, 10:38 AM
Those are polished aluminum wheels with a clear coat on top. Treat them as you'd treat any aluminum body panel with paint and clear coat. Use a mild PH balanced cleaner (make SURE you take note of the PH level) and if they are really dirty I suppose once a year you can use a VERY mild clear coat polish.
If the rims are bad, you should demount, clay bar, polish and keep them nice from that point to avoid having to go balls to the wall every cleaning session.
If you're not sure of the PH levels of cleaners just go with something that says "polished aluminum safe". Even though it's not raw polished aluminum you'd really benefit from using the weaker PH cleaner. Hell everyone should, those strong wheel cleaners over time accelerate the dry rotting process and dull the rims clear coat.
When you are using a rim cleaner and you spray tires/rims that are perfectly clean and you keep getting brown grime, that's not grime, that is the protectant inside the black rubber to prevent dry rot/cracking and the cleaner is too strong so it's pulling all that stuff out of the rubber which is why people always say "no matter how much I clean my tires I keep pulling off brown crud". It took me a while to really believe it but once I did all of the sudden my tires could literally go 2x to 3x the amount of time and not the slightest hint of dry rot/cracking.
Now dulling the rim's clear coat, oh man I could go on forever about that.
All I'm trying to say is if you detail your car enough you never even need a rim cleaner, you're just wasting your money and stocking one more product. 99% of the time all you need is the left over soapy water you used to wash your car and that will be more than strong enough to clean your tires/rims (the inside of the rims too, don’t forget about them). That's all I use and I save money, my rim's clear coat is clearer for a longer amount of time and I don’t have to worry about the life of my tires anymore.
I am VERY into detailing and the science behind it. It's not just using soap and water, I treat my car the same way someone treats a Bugatti from the 30's.
r34220
08-02-13, 12:12 PM
All I'm trying to say is if you detail your car enough you never even need a rim cleaner, you're just wasting your money and stocking one more product. 99% of the time all you need is the left over soapy water you used to wash your car and that will be more than strong enough to clean your tires/rims (the inside of the rims too, donít forget about them). That's all I use and I save money, my rim's clear coat is clearer for a longer amount of time and I donít have to worry about the life of my tires anymore.
Thanks for the explanation. Right now I am just using the same soap (Griot's Garage Car Wash) as I use on the paint so it looks like I will stick to that. I had wash at least once a week so they should always be easy to clean with just the soap. As you can see from the picture that its doing the job pretty well as the car is 3 months old with 4k miles.
joesboat
08-06-13, 09:18 AM
Yeap, you're wheels look......brand new (they should anyhow). Keep doing what you're doing and you'll never need to do more than splash them with some mild soapy water.
Let them go and you'll have bubbles in the paint, pittings, dirt so heavy it'll take hours to clean em.
Something about looking at my 20 inch wheels and the inside of them being white glove clean gives me a smile. My wife thinks it's silly but she doesnt stop me from detailing her car weekly.
