dolomite41
03-08-05, 12:02 AM
I need help on hooking up the power antenna to my New cd player deck...what wire do i use and do i have to go in the trunk and find the wire..help help
| View Full Version : 96 Fleet Power Antenna dolomite41 03-08-05, 12:02 AM I need help on hooking up the power antenna to my New cd player deck...what wire do i use and do i have to go in the trunk and find the wire..help help BroughamOnChrome 03-08-05, 02:19 PM Should be the blue wire coming from the deck to tell the antenna when to go up and down and depending how you hooked up a aftermarket radio you may be able to locate this wire in the trunk. Technupe 03-19-08, 07:32 PM I need help on hooking up the power antenna to my New cd player deck...what wire do i use and do i have to go in the trunk and find the wire..help help I am having the same if not similar issue with my Fleetwood. But included in mine is that there is a problem of my antenna not going up or down since the radio is now hooked up. Electricity is going to the antenna but the mast does not move on its own. My_favorite_Brougham 03-19-08, 09:33 PM Check the power antenna fuse, as it may have gotten blown in the exchange. The antenna will still receive w/o the fuse, just not move. | |
