: 85 Fleetwood Brougham Climate Control issue
j2rossit
07-27-13, 10:31 AM
I've discovered a nagging problem that I'd like to try and get on top of.
The A/C doesn't always turn on. Some times when I first jump in the car I'll need to turn the climate control on and off a few times before the compressor will kick on and start to blow cold air. Once the A/C starts, it seems to work fine after that, but the next time I jump in the car, again I'll have to play with the buttons for a while before it will kick on again.
I don't know if it's related but I also have a problem where as I'm driving down the road occasionally the fan will turn off for about 2 seconds and then come back on to full strength. That happens once or twice a trip.
I'm trying to figure out where to look first, climate control head? the control unit under the glove box? A bad ground somewhere?
The lights on the climate control unit and the display always seem to look like they are doing what I expect, so it's not a contact problem with the buttons.
cadillac kevin
07-27-13, 01:59 PM
Jon, if it's a problem with the CC head, I have a spare lying around (remanufactured delco)
j2rossit
07-27-13, 02:13 PM
I haven't quite figured out how I'm going to test the components since it's just an intermittent problem. Another symptom I'm having is that if I leave the A/C on for a long highway trip, it seems to get weak and then quite after about an hour. After it sits for a few hours it comes back good as gold. But if I keep switching back and forth from auto to econ, it will work indefinitely. I'm wonder if the cycle switch at the evaporator is starting to give out.
How much do you want for the CC head? I'm looking at getting one from a local wreckers if they'll ever send the guy out in the yard to see if the car's still there (they wont let outside people into their yard). Does anyone know if the units are standard and can be switched from metric to American units or if they are two separate part numbers?
I have a brand new NOS resistor module in the car so I don't think it's related to that.
cadillac kevin
07-27-13, 02:58 PM
30 bucks ok? BTW, I'll be getting a shipping quote on your 2nd box next week. All I have left is to get the alternator pulley off my dead 307 alt.
j2rossit
07-27-13, 06:10 PM
Yeah, I'll take it for $30.
j2rossit
07-27-13, 07:23 PM
Just to double check, the CC head you have is for the HT-4100 and has the rear window defroster?
cadillac kevin
07-27-13, 07:37 PM
I don't remember what year it is from. It is a direct fit for my 86, and has rear defroster. I don't know if the 307 units will work in the 4100 cars or not (if they look the same).
j2rossit
07-27-13, 09:31 PM
The 4100 cars had the trouble code reader through the climate control head. It had a built in diagnostic for the TBI. Somehow I doubt the olds equipped cars had the same CC head.
grauhst
07-28-13, 12:08 PM
They won't fit on HT4100 cars. You need a 82-85 one.
Bought a later one too and saw that the Fuel Monitor is not working with this one.
cadillac kevin
07-28-13, 12:11 PM
So would it have to be from a deville or would one from a 4100 powered eldorado work? It would have the diagnostics, but I am not 100% sure it is the same size/ has the same pinout.
grauhst
07-28-13, 01:04 PM
I think it doesn't matter, but no warranty to this.
brougham
07-28-13, 04:53 PM
As long as the fuel data center isn't part of the control head itself it should be the same part.
Remember that it won't blow cold all the time and the fan speed is also automatic. If the car senses that the interior temperature is where it should be the fan speed can lower and the ac won't come out as cold until it's needed again to maintain the temperature. If you have to turn it on and off a couple times to make it come on it could be that the blend door isn't working right.
grauhst
07-28-13, 05:53 PM
That doesn't matter. My FB with HT4100 has seperate control head and fuel monitor too.
http://up.picr.de/15328260lw.jpg
'86-'89 Brougham control head fit, but fuel data panel is not working with it. Just had this problem and unfortunately bought a '86-'89 one. Works great but as I said, no fuel monitor. The control head for HT4100 cars have another plug at the backside that goes to the fuel data display.
Bought a correct '82-'85 one and now it works.
Regards
Felix
Here you can see the additional plug.
In these two links are an Eldorado control head and a RWD control head. They have the same part number. So they all used the same control head on all HT4100 models.
#1 (http://www.ebay.com/itm/1982-85-Cadillac-Electronic-Climate-Control-Head-/261190669708?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cd02d558c&vxp=mtr)
#2 (http://www.ebay.com/itm/1985-Cadillac-Eldorado-AC-Heater-Climate-Control-Assembly-16016886-Works-/200946122753?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ec9528001&vxp=mtr)
This one is a '86-'89 one. You can see the missing plug.
#3 (http://www.ebay.com/itm/82-89-CADILLAC-DEVILLE-FLEETWOOD-AC-HEATER-CLIMATE-CONTROLS-TESTED-WORKS-83-84-/161073816310?pt=Vintage_Car_Truck_Parts_Accessorie s&hash=item2580bf62f6&vxp=mtr)
Regards
Felix
mhamilton
07-30-13, 04:30 PM
The evaporator is freezing up on highway trips... you're getting low on refrigerant. Don't just add indiscriminately, check the inlet and outlet temperatures of the evaporator lines while the ac is running, and check both high and low side pressures.
For the issue where the ac is not engaging, check with a test light or voltmeter at the compressor clutch power connector when the ACC is on, but the compressor is not active. If you have 12V there, then nothing is wrong with your ACC. It would likely be a wide clutch gap or weak clutch coil. If not 12v, check for 12v at the evap pressure switch, then back to the ACC unit.
j2rossit
07-30-13, 04:44 PM
Yeah, I think the evaporator is freezing which is why I'm suspicious of the cycle switch. It's supposed to shut the compressor off if the evaporator goes below 0 deg C and reengage the compressor when the evaporator warms to above 7 deg C.
The system is charged and both high and low side pressures are good.
I'll try and get what ever voltage readings I can when the system is giving me grief (it's been acting properly since I made the post here so I don't have much more to update). I hate intermittent problems.
j2rossit
08-03-13, 03:09 PM
So I've got an update, It started acting up again today so I popped the hood and gave a tap to the cycle switch. The instant I hit the switch the compressor kicked in and the A/C worked fine after that.
So my question is: how to replace the switch? There is a charged tube that goes down into the evaporator. Is there a bolt on the other end? can you just pull it out? I can't find a replacement on Rockauto so does anyone know where get a new switch?
mhamilton
08-08-13, 04:58 PM
On an '85? The cycling switch should be screwed onto a port on the accumulator. There's a schrader valve under it, so just unscrew it and then put on the new one. 2 minute job.
j2rossit
08-11-13, 10:30 AM
On the 85 the switch is mounted on the air plenum beside the blower motor and comes with an integrated tube charged with freon. The tube runs along the inlet pipe to the evaporator to measure the temperature of the freon entering the evaporator. The tube cannot be separated from the switch but I've found out that it isn't held on to the evaporator inlet pipe with much other than some goop and is really easy to remove and replace.
Robin Banx
08-13-13, 11:08 AM
Mine is acting up as well. Started intermittently a couple of years ago. I didn't know what the problem was until your post. When the A/C compressor quit last week during our annual heat wave, I left the car running, popped the hood and tapped the cycle switch and presto, cold air again and no further trouble. Lordco Auto parts, our local Delco dealer doesn't stock the Delco switch any more but they do have a variety of replacements available. I have asked for any one of them NOT made in China.
Cheers.........R.
