: Brakes still pulsate after new pads and rotors-2002 Escalade
soloncamper
07-25-13, 09:10 PM
The brakes on my 2002 Escalade were pulsating when I was slowing down from highway speeds. I replaced the rotors and pads and it helped a little bit, but I can still feel it. Could the calipers need to be replaced? I do not know if they have ever been worked on or not.
Thanks
wesyder
07-25-13, 09:19 PM
Thanks
Possible rust or debris between rotor and hub
soloncamper
07-26-13, 09:08 PM
I think I cleaned the hub very well before I installed the new rotors. How can I tell if I have a bad caliper?
wesyder
07-27-13, 11:28 AM
The caliper will either leak or get stuck when bad, question, is the steering wheel shaking when braking or is it a pulse like the brakes are be applied on and off
the cadillac man
07-27-13, 11:36 AM
I hate to threadjack but my truck does the later in the rear where it feels like the brakes are plus ring on and off in rapid fire movement (I think its my rotors as I put new brakes on the rear not too long ago and it still does it)
wesyder
07-27-13, 12:02 PM
No prob... Yeah if its in the steering wheel its most likely the front if you jus feel pulsing like a slight on and off the brakes its most likely the rear
the cadillac man
07-27-13, 12:30 PM
Mine does it in the rear
bigirb2002
07-29-13, 03:43 AM
are you sure your not just feeling the abs kick in? abs has a pulsing feel to it because the caliper is opening and closing at a rapid pace.
MoistCabbage
07-29-13, 03:48 AM
Did you replace the pads and rotors on all 4 wheels?
wesyder
07-29-13, 11:01 AM
Its a very smooth pulsing not as violent as abs
the cadillac man
07-29-13, 02:36 PM
I know but this shakes my whole truck literally and it doesn't do it all the time so I don't think its the abs(my dads hummer h2 doesn't.do this at all)
wesyder
07-29-13, 03:37 PM
Should be mostly when the rotors get hot , like aggressive braking or hi speed braking
Skier-24
07-29-13, 08:40 PM
[QUOTE=wesyder;10618353]Should be mostly when the rotors get hot , like aggressive braking or hi speed braking[/QUOTE
Maybe a caliper is not completely releasing, causing a rotor to overheat and warp.You can check for this condition with a non-contact infrared thermometer. both sides on the front should be close to the same temperature and both of the rears should have similar temperatures.
the cadillac man
07-30-13, 02:47 AM
When the abs does engage it sounds like rapid fire pulsing from the rear instead of smooth braking(my dads h2 is smooth braking)
I told the service manager and he said it sounded like I have a warped rotor
I know warped rotors are caused by heavy excessive breaking(I rarely have to panic stop unless someone stops sudden and I have to avoid hitting them)
I have heard if you ride the brakes a lot it does this(I don't but who had the truck before may have))due to warping the rotors
MoistCabbage
07-30-13, 02:51 AM
Rotors don't "warp". Excessive runout is caused by uneven wear.
the cadillac man
07-30-13, 09:57 AM
I am still going to have to replace my rear rotors because of it
Skier-24
07-30-13, 11:44 AM
They will overheat when sticking caliper causes the pads to drag and cause temporary warpage. Been there and done that. Replaced sticking caliper and pulsating never came back.
MoistCabbage
07-30-13, 11:49 AM
Overheating can cause excess pad material to stick to the rotors, which can be removed with some hard brake applications from highway speeds to ~20MPH or so.
Again, rotors do NOT "warp", they're cast iron.
the cadillac man
07-30-13, 12:54 PM
Tried that and it didn't help
Also not all rotors are of the same material
Last time I had my rear brakes changed they said my rotors needed replacing next time anyway as they couldn't turn them as they were already to the limit
I am going to save up and have front and rear brakes(including the park brakes)along with my rear rotors replaced soon so I don't have to have this happening as I know its NOT normal
Skier-24
07-30-13, 11:07 PM
"Again, rotors do NOT "warp", they're cast iron."
I guess Monroe has been wrong all these years. Copy and paste for the facts:
http://www.monroebrakes.com/support/brake-problem-diagnostic/types-of-failures-rotors/disc-brake-system/warped-rotor/wheel-vibration?utm_source=google&utm_medium=cpc&utm_content={K_CREATIVE_HEADLINE}&utm_campaign=Rotor+Symptoms&utm_term=%2Bwarping%20%2Bbrake%20%2Brotors
MrHolland
07-30-13, 11:14 PM
If your brake hoses fail they can also cause your brakes to shake. Anytime I replace a caliper I also replace the hoses. Its been my experience that hoses are what cause brake caliper failure. JMHO.
the cadillac man
07-31-13, 02:49 AM
I looked at the link (they mention warping)
I am not making claims but there are companies that don't have cast iron brake rotors but that's a different story(one I don't want to get into)
I do know my rotors are shot for sure(known it since the last time I had my rear brakes changed) as they can't be turned as they are really thin from previous jobs
Haven't had a hose fail yet(knock on wood)but I do inspect them when the wheels are off the truck for cracks or damage
MrHolland
07-31-13, 01:10 PM
The inside deteriorates and sometimes will maintain pressure on the caliper which will cause the caliper to fail. Therefore when I replace a caliper that has failed I also replace the hose.
the cadillac man
07-31-13, 01:22 PM
I see
So far I haven't had to replace a caliper but never know
