tactical64
03-06-05, 02:05 AM
After parsing the forums about the throttle body cleaning procedures, I am left with some questions.
1: My throttle body was extremely bad, black, and covered with a thick layer of carbon buildup, After cleaning twice, I feel that cleaning the rest of the black carbon from the whole inside of the intake manifold must be a better way to go.
I failed to disconnect the battery terminal after either cleaning, I found today that I should have done that to complete the job basically. I drove the car 3000 miles in a week to miami from TN after the 2 cleanings. It ran much better. However i feel that the TPS computer adjustment offset or whatever that was not done will now improve the gas mileage once again and lower the idle on cold start. I will reclean the throttle body again and perform the reset.
I did not clean the "fuel pressure regulator" or the "egr valve" With my engine having 103k miles I bet I should perform these easy tasks as well. My sticking gas pedal and loping engine was fixed in the original 2 cleanings which took place 2 weeks apart to prepare for that taxing trip. I just know that I could have and need to do more.
The spark plugs are new Autolite double platinum * the right ones, *the Bosh plats performed horribly. The wires are new Belden and the air filter is new.
So what of the extremely dirty inside of the intake manifold past the throttle body internally?
I had a MotorVac service performed by some trusted honda specialists previously and so when I later saw the incredibally dirty throttle body and intake I was of course stunned.
