: Grinding Sound
pVu
07-24-13, 04:47 PM
I just noticed when I turn left or right I can hear what sounds like to metal grinding. Has anyone experienced this issue? I think it's my rotors, but I could be wrong.
Any suggestions....
Trapspeed
07-24-13, 06:44 PM
Grinding, not clicking??
PNBLWZD
07-24-13, 09:54 PM
I had a grinding/howling sound coming from the rear differential when I would turn L/R when the car was cold. Had the dif serviced today per the TSB referenced in the rear end symptom thread, and so far the noises are gone and there were no metal chips on the drain plug magnet. I'll know for sure in the morning when it's really quiet outside and the car is totally cold, but so far sounds quiet.
pVu
07-24-13, 10:33 PM
Trapspeed, it was a clicking sound on Monday and they told me it was my rotors. Today, it's making a
grinding noise. Idk what it could be.
Pnblwzd, it sounds like it's coming from the front tire area. Who knows at this point...
Trapspeed
07-24-13, 10:56 PM
I see you're driving an '09. Chances are it never had the additive and refill TSB done which may not be helping. Anything that sounds like grinding from the carrier is leading to a bearing failure sooner than later. Is it still under warranty?
pVu
07-25-13, 01:42 AM
Yes, but it's actually a 2011.
Cadillac Cust Svc
07-25-13, 09:42 AM
Hello pVu,
I see you have engaged with other forum members in regards to your grinding sound on your vehicle. I apologize for any inconvenience this vehicle issue is causing for you. If you are thinking about bringing your vehicle in for a diagnosis at the dealership, please let me know. I can also check for what is associated with your vehicle if you provide me with your VIN. I can be reached via private message.
Sincerely,
Laura M.
Cadillac Customer Care
pVu
07-25-13, 10:23 PM
Thank you Laura. I just got it back from my local dealer and he said that my aftermarket headers are causing this issue.
P.S. You are so helpful, thank you again for everything that you do for us.
Trapspeed
07-25-13, 10:58 PM
Checked your profile. Thought I saw an '09.
pVu
07-26-13, 01:36 AM
I will look at my profile.
Trapspeed
07-26-13, 07:59 AM
It's possible I checked the wrong member but I thought I had yours! No worries.
Cadillac Cust Svc
07-26-13, 09:16 AM
Hi pVu,
You are welcome, and thank you! We are here to help our customers, and I am happy to hear you find us helpful :) Thanks for updating me on your vehicle. Is the dealer able to fix this issue for you?
Laura M.
pVu
07-26-13, 04:44 PM
No, the dealer won't fix because I put those headers on the car.
PNBLWZD
07-26-13, 04:49 PM
Why would headers be causing a grinding noise, unless they are rubbing/vibrating on something like the frame? I would suggest getting a second opinion on that diagnosis.
pVu
07-26-13, 04:57 PM
I was told that the motor shifts from side to side when making turns. The headers are like a few millimeters away from the subframe and the oil something they said. Who knows really?
spearfish25
07-26-13, 05:21 PM
I think the dealer is wrong. My car is essentially bone stock and when I'm driving slowly in a parking lot under full lock, I hear a rubbing/grinding too. No idea what it is.
pVu
07-26-13, 07:24 PM
Hmmm...I wonder what it could be. Have you had yours checked out?
spearfish25
07-26-13, 07:51 PM
No, but I'm going to have her on jack stands in the next week or so. I'll turn lock to lock and see what I see then.
pVu
07-26-13, 11:41 PM
Keep me posted
