View Full Version : Codes 13 31 45
Scottie in Alabama
03-05-05, 12:33 PM
My 'check engine' light has been flashing on every now and then. Usually when on the interstate. For a few seconds and then off.
I pulled my codes a little while ago, they were 13, 31 and 45. I looked them up to be:
13 Oxygen Sensor
31 Canister Purge Solenoid
45 Oxygen Sensor (Rich Exhaust Indicated)
Two questions,
Will replacing the O2 fix 13 and 45? (I changed it about 3 mos ago!)
What is the Canister Purge Solenoid and how do I fix that problem?
Thanks guys
Oh, by the way 89 brougham 307
pimpin88
03-06-05, 09:57 PM
are you experience bad gas mileage? i am getting about 10 mpg and i think the canister purge solenoid is the culprit. the code i pulled is code 31. i am also unsure as what to do with this problem besides getting another purge solenoid from my mechanic?
Scottie in Alabama
03-07-05, 01:33 PM
Pimpin, my gas mileage is not that bad. Never done the actual math, but if I had to guess, I'd say around 15-17 city and 21-23 hwy. That's if I keep it between 70-75 mph. I'm sure it's suffering some from the O2 and whatever the canister purge solenoid is. But overall it does fairly well. I am very interested in getting the problem solved. I was reading the codes in my 'Haynes' manual and they both (13 and 45) say to check a couple of things and/or change the sensor. Which is probably the simplest thing to do, but I would like to know why I am having to change it so soon. Perhaps the system was so clogged from sitting for so long (the car) that it just clogged this one up. But I don't know anything about the canister purge solenoid, not even where it is. It's not in the emissions diagram.
pimpin88
03-09-05, 12:13 PM
if i'm not mistaken i think the canister purge solenoid is on top of the intake manifold near the oil filler neck. has a plug going into it along with two vacuum wires. its like a little black box looking thing. just follow the vacuum lines and you should be able to find it.
