: has anybody done transmission program update?
Crijan11
07-23-13, 10:48 PM
Does it help any with the noisey shifts and gear selecting noises. What was the cost associated with it
RichieRich
07-23-13, 11:21 PM
I did... It didn't stop the noises... Changing the transfer case did.
hcvone
07-24-13, 07:31 AM
If you have noise that is another problem, the reprogramming fixed the bang on the downshift, it was mostly for 2007-2008 trucks
Crijan11
07-24-13, 12:38 PM
I don't mind the noise as much as I hate the clunks on the down shift. Thats the only thing I'd like to get rid of
Maliburider
07-31-13, 01:21 PM
I have the same "clunk" problem. I have an 08 EXT and if I am on the highway say 60 mph and step on the gas a little and it downshifts the whole truck like clunks like the engine is to slow for the lower gear change. I would like to take it to the dealer and pay get the transmission software update only. I took it to my local dealer today and they want $120 to diagnose and another $160 for the software update if needed. I want to be able to just get the software update if needed. How do I know for sure that my vehicle would benefit from it?
hcvone
07-31-13, 01:55 PM
You would need to know what update your truck has compared to what update they are up to, of course you can only get that from the dealership or someone with a Tech II tool, they want too much money, the update would take 15-30 minutes and that includes downloading the latest program from the GM computer, do you have any other dealerships in your area, you may want to find one that does not want to take all your money.
blackex
07-31-13, 02:08 PM
I figure my software is probably out of date however since i'm not getting any banging noises unless I tap on the gas from slowing down at low speeds I get a clunk from the transfer case it sounds like, I figure I won't change anything or update the software since it could create some issues I didn't have before. I learned many times if it's not broke don't try and fix it because it just creates more problems, expensive problems.
Cadillac Cust Svc
07-31-13, 06:17 PM
Hello Maliburider,
We are sorry to hear that you are experiencing an issue with your vehicle and may need a Transmission program update. Can we be of any assistance?
Jennifer T. (Assisting Laura)
Cadillac Customer Care
hollingass
07-31-13, 09:17 PM
I think it is wrong for any dealer to charge for these updates, the fact that there is an update says the original programming is not acceptable. I have these same symptoms but if its going to cost me hundreds to fix it i will consider another brand next time
mycaddi408
08-01-13, 03:18 AM
this is why they call the dealer the "stealer"
hcvone
08-01-13, 06:41 AM
Any manufacturer is going to charge you for this no matter what brand of auto you purchase, most dealerships will do this if you tell them you are not buying their used truck without this service performed, and you can also get them to print you out all the service performed on that car/truck before you buy it, these are all tools you can use to make sure you are getting the most up to date info in your new purchase. :)
Mr.SWAG
08-01-13, 11:47 AM
I was able to fix the clunking problem by changing the u joints
Maliburider
08-02-13, 10:05 AM
Assuming my 2008 has original transmission programming, is it worth spending the $160 to get the update? I don't mind paying for it if its a known fix or TSB etc that would help me. Granted I know there could be something else wrong like u-joints or transfer case. But assuming all the parts on the truck are good, then would it be worth it to just take it to Cadillac and just say "do the update"?
hcvone
08-02-13, 10:16 AM
Only if you have the banging when the truck downshifts when you come to a stop, that is what it fixed in 2007-2008, there maybe other updates that will make your trans perform better as well, but that is just a guess without driving your truck and knowing what updates it has had done to it. :)
wwceaton
08-03-13, 08:26 PM
Hear is another TSB for your SUV
•A/T Controls - Hesitation/Lack of Performance
Bulletin No.: 07-07-30-030
Date: November 21, 2007
TECHNICAL
Subject:
6L80 Automatic Transmission - Hesitation, Lack of Performance, Difficult to Obtain Downshifts (Reprogram TCM)
Models:
2007-2008 Cadillac Escalade, Escalade ESV, Escalade EXT
2007-2008 GMC Sierra Denali, Yukon Denali, Yukon Denali XL
with 6L80 Automatic Transmission (RPO MYC)
Condition
Some customers may comment that the vehicle has a hesitation or lack of performance when attempting to accelerate with moderate throttle apply in the 56-113 km/h (35-70 mph) range. They may also comment that it is difficult to obtain transmission downshifts in the same 56-113 km/h (35-70 mph) range.
Correction
A revised transmission calibration has been developed to address these issues. Reprogram the transmission control module (TCM) with updated calibration files using the TIS2WEB Service Programming System (SPS) application. As always, make sure your Tech 2(R) is updated with the latest software version.
These calibrations will be "selectable" and should only be used to correct a customer concern as detailed above. Use of this calibration in a vehicle without these concerns may result in comments of busy shifting.
Warranty Information
blackex
08-03-13, 08:52 PM
Thats an interesting TSB since I have noticed that the transmission/engine do not seem to slow down when letting off the gas around 35-50mph.
tagg
08-06-13, 02:55 AM
I have this same issue. Just got 2008 escalade 2 months ago. tranny clunks when downshifting at highway speeds. I have also noticed a burning type smell that only happens once after startup and when I first go up hill. it usually comes thru the a/c vents while a/c is on. I had tranny fluid flushed but hasn't seemed to help.
Royalton
08-07-13, 01:39 AM
Is it this TSB?
http://www.justanswer.com/cadillac/3xy4e-tsb-address-transmission-flare-2nd.html
Cadillac Cust Svc
08-07-13, 09:19 AM
Hello tagg,
I am sorry that you have a transmission clunking issue when downshifting at higher speeds and notice a burning smell that happens after startup when going up a hill. I would like to further discuss your concerns with you. Please contact me via private message and include your VIN with current mileage.
Sincerely,
Laura M.
