: 94 fleetwood brougham rear suspension ?'s
low94
07-23-13, 08:11 PM
Noticed that my compressor does not come on at all nor do I get a light on the dash I ran power to the compressor manuely and it lifted the back any ideas what it could be also how do I adjust the height
turbojimmy
07-23-13, 08:55 PM
Check the yellow wire that runs from the sensor to the connector at the rad support. It then runs to the relay on the pump. The sensor provides a ground to activate the relay. By grounding it, the pump should run. Not only does it activate the pump relay, it also lights up that dash light. Mine was broken inside the connector at the rad support. I jumped around it with a couple of wire taps.
low94
07-23-13, 09:51 PM
Is it a yellow connection with a black n white wire that's all i could find
turbojimmy
07-23-13, 10:09 PM
The yellow connectors are airbag connectors. Don't mess with those.
There's a black connector near the rad support, by the air box, that has the wires from the ride height sensor. One of them is yellow. I'm pretty sure you'll find that is your problem. You should see a ground on that wire when the system calls for the pump to turn on. The pump isn't seeing it. Could be at that connector or anywhere in between.
