View Full Version : Power per dollar
davesdeville
09-30-03, 10:57 PM
If you had a finite amount of money... lets say $2500, what kind of engine would you build up and why / how? The goal is the most power you can get out of it without making it a race dedicated engine.
DeVillish
09-30-03, 11:56 PM
i think i would go with a sbc 350. Theres such a huge market that parts are pretty cheap, theres more avalable and with so many resorces on them it would be easy.
MMNineInchNails
10-01-03, 01:09 AM
No question about it. I think everyone would go for the 350. It's the cheapest engine to build up and they have so many parts for it, it'd be the best.
AKPsiMC03
10-01-03, 06:18 AM
one of my friends just built a 433 HP, 460 ft lb, 350 for that price and put it in his firebird.
JJhomer83
10-01-03, 10:12 AM
The 350 is your best bet. Your going to have to do a lot of research on what parts to put on it to get you the most bang for your buck. I recommend going to a library and reading hot rod mag, Super chevy etc.... they have budget motors in there mags all of the time. Also look into a rebuilt motor and rebuilt parts. Heads, cam, carb, exhaust, etc....
davesdeville
10-01-03, 07:10 PM
I was thinking that too. Then I thought I'd look for things I could do with a Cad500 when I get one, and I figure
$250 for a usable 500 from a junkyard
$250 for an Edelbrock performer intake
$500 for 10:1 pistons
$450 for cam, lifters, valvesprings
$200 for a good set of headers
$200 for a carb, or maybe keep the good old stock Qjet and clean and tune it.
With those mods, I'd expect the Cad to hit around 410-450hp with 500+ torque. The cost would total $1850, so even if it didn't hit my estimated power, there's enough money left over to put a good nitrous system on there for an extra 150-250hp.
I don't know if that setup would be better than a 350 though since I haven't looked into 350s much.
MMNineInchNails
10-01-03, 07:21 PM
Q-Jet wouldn't work with your edelbrock performer intake. I suggest getting an edelbrock or demon 850cfm carb for that setup.
Blackout
10-01-03, 07:45 PM
I don't get the question. Your asking to modify an engine but not to make it race dedicated :confused: obiously once you start modifying an engine it will be producing more hp/tq which would mean better performance which would be better for racing.
davesdeville
10-01-03, 08:45 PM
Alright if you want to be a pain about it, I mean an engine that is still useful as a daily/weekend driver. So it doesn't need race gas, doesn't need work after every run, etc. Of course there's no chance of making a pure race engine for $2500 anyway. Also, it's obvious that any performance increase would be better for racing but it's also obvious that performance modifications don't always result in a pure race engine..
AKPsiMC03
10-01-03, 10:06 PM
wait... how long does the motor have to last?
cus if not long, get a junk yard 350, make a custom turbo kit for it, then blow a 250 shot through it :D
Elvis
10-01-03, 10:14 PM
I have to admit I was salivating last night when I was doing 1/8 mile test runs in the Fleetwood I borrowed.
I agree with MM9. The LT1 has a lot of potential with just simple bolt-ons. And it was pretty common, too.
The Fleetwood was scary when I started thinking of all the extra power I could get out of it with just a few hours here and there and a only few hundred dollars spent. I used to spend my Sunday afternoons watching shows like "Crank & Chrome" and being shocked and awed by their dyno runs.
But I think I'm over that after my Honda Prelude/riceboy experiments. They were fun, and they did yield some respectable results, but I don't want to do that kind of stuff to my daily driver anymore.
What deterred me and brought me back down to earth was how I would probably end up spending twice as much on brakes and suspension to counteract the increases in HP. That's not the kind of work I know how to do, or ever want to learn.
davesdeville
10-01-03, 11:34 PM
Hmm, that sucks. At Jegs, it says the stock ac compressor won't fit - they should probably warn people that the carb won't work either. Can you tell me why it wouldn't work?
MMNineInchNails
10-02-03, 01:02 AM
well you might be able to use it if your intake manifold was either built for a q-jet or was all open, instead of the four ccut out circles. The Q-Jet doesn't have equal size for the manifold, the Secondarys are a lot bigger than the primarys, so they wouldn't fit into the manifold. I don't know if that just confused you. I don't really have any better way to explain.
Here is a picture of the Q-Jet Gasket to let you know what i'm talking about
http://www.nardek.com.au/nard040.jpg
Here is a picture of an intake manifold
http://www.boss302.com/intake4.jpg
see what i'm talking about? They're all equal size and secondarys wouldn't fit.
I guess you could just go for a box open intake manifold, but you why do you want to go with a Q-jet so bad? Just get a regular edelbrock or demon carb 850cfm would be nice. q-jets just have a bunch of extra shit on them.
davesdeville
10-02-03, 06:38 PM
The intake manifold pic you have doesn't look like the Edelbrock one:
http://static.summitracing.com/global/images/prod/large/edl-2115.jpg
http://www.jegs.com/photos/3502115.jpg
It says the manifold will work with square or spread bore carbs, which doesn't help me cause I don't know what that actually means. With the Jegs pic and the gasket pic, it looks like it could work though.
I'd like to be able to use a QJet because I have one... which is cheaper than buying one. QJets are perfectly good carbs.
lux hauler
10-02-03, 11:06 PM
I don't mean to get off topic here.....I just wanted to give a little info on carbs and intakes.
There are adapters that will let you mix and match carbs and intakes.
Here's a link that shows some of the adapters Edelbrock has.
http://www.edelbrock.com/automotive/install1.html
I think I'm going to use the Q-Jet (rebuilt and modified, if needed) on my 500 with the Edelbrock Performer intake.
davesdeville
10-02-03, 11:14 PM
Wow, I was looking at that about 5 minutes before I saw your post. And yeah this went off topic a while ago.
Can anyone tell me if the edelbrock manifold will fit a QJet without an adapter? If I put it in my 78, the air cleaner assembly I have won't fit under my hood.
Blackout
10-03-03, 03:11 PM
I'd buy a 1989 Nissan 240SX throw a turbo on it and throw on some a 100 shot of nitrous and walla! Instant low 13 sec 1/4's!
davesdeville
10-05-03, 03:39 AM
An Edelbrock performer manifold (2115) can be used with a QJet. Found that out by rereading Cad Companys catalogue.
MMNineInchNails
10-05-03, 04:10 AM
You really want that q-jet, huh? what cfm is it?
500-CID
10-05-03, 06:37 PM
Dave, I think you know my answer..:burn:
davesdeville
10-06-03, 02:30 AM
Yeah I guess so :D What kind of 75 Caddy do ya have?
795cfm I believe and I don't see enough differance between a QJet and any other carb to justify spending any money on it.. keeping in mind that I already have the QJet so I won't need to spend any money on it except maybe some carb cleaner.
MMNineInchNails
10-06-03, 01:15 PM
Yeah, you should rebuild it too, if it's not already rebuilt.
500-CID
10-06-03, 07:12 PM
Its a coupe deville:D
JJhomer83
10-07-03, 10:21 AM
Hey all who is looking for carbs, rebuilt carbs or to have yours rebuilt. There is a guy down the street from my house (4 doors down) who does that all day long. I know he has stuff on ebay his website is carbdoctor.com He did the carb on my chevelle and it is a work of art. Completely cromed out, and looks/works great
bob2231
10-26-03, 06:20 AM
Blackout, I've seen several of your posts and I really need to ask a question. I'm not being a jerk so don't get emotional abouthis, it's just curiosity.
People ask questions related to buying or working on a Cadillac and invariably you seem to memtion how you would spend the money on some sort of Asian import. And that wasn't what was asked. Your info descrices you as a "Cadillac fan" but you don't own one and keep telling everyone to buy Jap.
My question is, Why are you here ? Wouldn't you honestly be happier spending your time at a forum dedicated to the cars you seem to love so much ?
Just honest curiosity.
You don't have to own a Cadillac to join this forum, but you don't even seem to like them at all.
Bob
Elvis
10-26-03, 08:54 AM
I don't own a Cadillac either. Don't even own an American car. Mine are Japanese, Swedish, and German.
But I'm emotional about the Cadillacs my parents had when I was growing up--I loved those cars (and I loved IN those cars! :histeric: ). Even after my test-drive of an Acura TL Friday I'm still very likely to pick up a DeVille when the time comes.
bob2231
10-26-03, 10:14 AM
I didn't mean to imply you had to own one. But I've yet to read Blackout having any kind of positive comment about Cadillacs. Or any other American car.
Maybe it's because I worked for GM for quite a few years, I don't know.
But you said yourself, you like the cars. That's a major difference.
JWalker
10-26-03, 05:48 PM
As for the original post about a $2500 dollar build
Some of your prices are a bit high
from me a cam springs and lifters are about $400
pistons are a little under $400
need to add rings $80 or a bit more
youll need gaskets/bearings
what you really left out is machine work and that will add around $1000 to your build if you intend to do it right
something to remember about a SBC build is that the engine will in no way or shape move a 4000 lb caddy like a 472/500 will even in near stock form
if you decide to do something i can steer you in the right direction and save you some money
later
JWalker
10-26-03, 05:57 PM
later
there are alot more parts missing such as pushrods /rod bolts/head and main bolts/header flanges to convert your chevy headers
and on and on
davesdeville
10-26-03, 10:12 PM
later
If you were talking about my 500 build up, that was mostly off the top of my head. It doesn't make much differance anyway since I can't afford to do anything other than a pretty much stock engine. I'm hoping I can do it without rebuilding the engine. There's a rusty coupe Deville up the street that I have to ask the person about.. dunno if its a 472 or a 500.
lux hauler
10-26-03, 10:51 PM
75 & 76 DeVilles had square headlights and came from the factory with 500's. 68-74 DeVilles had 472's.
Cadillac Pat
10-27-03, 12:16 AM
Dave,
Sorry to find this so late. You were right in the beginning about parts and building up a 500. A STOCK 500 ('71-73) makes 375 hp and 500 ft.lbs. of torque. The best engine, the'70 Eldo, makes 400 hp/550 ft.lbs.. The last of the 500's, the '76, was the lowest at 300 hp and 468 ft.lbs..
The Edelbrock intake is specifically made for the original Q-Jet. Also, the original Q-Jet on all 472/500's is 800 cfm which is good to 500 hp. The STOCK A-6 compressor will not fit. This is what they are refering to. However, the newer style R-4 compressor might. You will have to modify/have made new A/C hoses. At the worst, you would have to build a compressor mounting bracket that raises the R-4 compressor.
While parts cost more for a 472/500, you START with much more and for a lot less. To have the Q-Jet get a performance rebuilt (the Carb Shop for example) is $300. They will professionally rebuild and set the carb up to your car/engine specs.
davesdeville
10-27-03, 01:01 AM
I'm glad I went ahead and rebuilt mine myself if it was going to cost me $300.. What do they do to call it a "performance rebuild"? Change jets, metering rods or something?
