View Full Version : Serious oil issue - overfilled the engine
Cadzilla8
07-22-13, 07:34 PM
So I check my oil maybe once a month. Checked it the other day it was like 1-2 quarts left check today bone dry... Added 7.1 quarts and now it's way over full... So confused need some help don't plan on using the car until I figure out what the heck I'm doing wrong
For the record I changed the oil like 2500 miles ago and have the northstar v8
scott9001
07-22-13, 07:39 PM
any marks on the laneway? how is the coolant overfulll?
Cadzilla8
07-22-13, 07:47 PM
No serious marks that could account for that much oil loss coolant is at the full mark the engine is cold and has been cold throughout this ordeal
The oil is about an inch / inch an a half over the thatched section of the dipstick how much over is that? How many quarts? Enough to do damage?
dkozloski
07-22-13, 08:31 PM
There is only about a quart difference between the top and bottom of the thatched area. If the oil shows at the very bottom of the thatch, that is a quart low. You better drain some oil before you break something.
Cadzilla8
07-22-13, 09:04 PM
Ok so I have possibly 5 quarts too much any sugguestions what to do? Should I do an emergency oil change in the driveway or can I drive less than 5 miles? Is it possible to drain some oil and close it back up or would that be insanely messy
So if the oil is at the very bottom of the dipstick does that mean I only lost 1 quart because that's what started this fiasco. It was at the very bottom and I thought I had lost 5+ quarts of oil so I added a big bottle
MoistCabbage
07-22-13, 09:24 PM
Just drain the excess, no need to change it, unless you're due soon anyway.
ddgm
07-23-13, 09:51 AM
I would drain it all out and put back in the required amount. Measure how much came out so you know what really went on.
When and if you need to add oil just add a little at a time and recheck the dipstick allowing some time for the oil to run down into the pan.
Doug
Cadzilla8
07-23-13, 11:43 AM
Yeah I made the mistake of adding it all at once and not checking in between. So the dipstick only measures 1 quart (like between 7-8quart mark) because when I saw the oil so low on the dipstick I thought I had lost 4-6 quarts but I guess losing a quart in 2500 miles isn't the end of the world
Submariner409
07-23-13, 11:55 AM
Northstar dipstick - pretty much the same for FWD and RWD ..............
<=== ADD XXXXXXXXXX OPERATING RANGE =========oo==========================O
1..........2 ...........3 ..........4 ...........5
1. 2 quarts low
2. ~0.5 quart low
3. Proper level
4. Too much oil
5. Dangerous - oil aeration and loss of pressure.
1 quart in 2500 miles is right smack in the middle of the GM design curve for oil consumption in a Northstar. Many CF Northstar owners would kill to get that sort of oil economy - particularly the FWD crowd.
Cadzilla8
07-23-13, 08:18 PM
Alright so I hope you guys don't tell me I just killed my engine... So I took out all the oil came out to like 13 liters. I then closed it up and put about 6/6.5 quarts in. The oil was mix of brand new oil and 2500mile oil so it was a little dirty. The oil now reads just over the thatched section of the dipstick. I plan on doing a legitamate oil change by the end of August now that I wasted 7 quarts. Well lesson learned.
dkozloski
07-23-13, 09:40 PM
Experience is what you have left after you've screwed up everything you own.
EChas3
07-24-13, 10:20 PM
It's probably fine. These are strong engines.
Good luck!
Charles Warren
07-28-13, 01:56 PM
If it were 3.8 then you'll be writing another thread something like "how much is an engine" lol
1BadCadSTS
07-28-13, 03:29 PM
Think you mean the 3.6 in which case over filling that much is preventive maintenance against chain stretch hahaha
KRSTS
07-28-13, 04:35 PM
No he means the Chrysler 3.8 L V6
dkozloski
07-28-13, 09:14 PM
If you buy a Chrysler minivan make sure it is at least 8 passenger so when you come to a hill 7 can get out and push.
Guy.Seminerio
07-28-13, 09:21 PM
Is that just an exaggeration because they used to suck or are they still that unreliable??
carter's_sts
07-29-13, 09:32 AM
Personally I banned Chrysler for life, but they are better than they were in the 80s.
EChas3
07-29-13, 10:50 PM
I've known a few to run for a while before blowing up or breaking in half.
Guy.Seminerio
07-29-13, 10:54 PM
I think the new 300 is freakin nice, especially the srt8.
I was at a Chrysler dealership about 3 months ago and a brand new 300 Srt 8 was in the showroom with moisture in one of the headlights.
carter's_sts
07-30-13, 01:33 AM
The 300 is a wannabe nice car.
Charles Warren
07-30-13, 12:03 PM
no gm 3.8 l67 to be exact
srt 8 engine is ok but i dont like mopar personally but ill thake a 300 srt8 any day over my gtp but if i had a stsv i wouldnt.
Guy.Seminerio
07-30-13, 12:28 PM
Exactly. Not over the stsv. Also really chrysler? A 5 speed on the srt8? I do think its a good looking car though.
Charles Warren
07-31-13, 05:08 AM
I like the way both sound. Most people think our cars sound like hemis lol well lets see hemispherical heads high compression but srt8 noise sounds a tad better but 4.6/4.4 vs 6.1/6.4 not bad for a smaller cubed engine. Just a bit cheaply made far as materials and to be honest looks like they bit off cts but cts was bit off by alot of others so has sts the last gen fusion looks like a caddy at a quick glance the new taurus was shaped off either. But it's not like 2000 Deville didn't look like a s class but the auto world designers move around so it's expected
1BadCadSTS
07-31-13, 08:47 AM
The gm 3.x series engines had intake manifold issues but I never heard of an oil issue. Not once did I see one go bad for that. Now coolant in the oil and spun bearing I've seen plenty of.
Submariner409
07-31-13, 09:34 AM
One of our vendors, SC2150, has posted some pictures of some pretty nasty oil pooling in 3.6 intake manifolds - due to the PCV system. His take is that, if you can't stop the oil carryover, at least install a catch can system to clean the PCV "dirty air" before it dumps oil in the manifold.
............ The Chrysler van thing - One of my stepdaughters/family had some sort of a Chrysler van a little while ago - nicknamed "The People Mover". It ran its nuts off day and night as well as 2 trips to the West Coast and back to Norfolk, VA - they had excellent service from it.
1BadCadSTS
07-31-13, 09:46 AM
Sorry I should of been clearer. I mean the 3000 series motors like warren inferred. The 3100 3400 and 3800. I don't consider the 3.6 of the same family as its a totally different engine (ohv vs dohc).
As for the 3.6 sisters 05 srx drinks 3 qrts every 1000 miles so I know all about that issue.
dkozloski
07-31-13, 02:30 PM
My stepdaughter has had a whole series of MoPar minivans. They spend more time on the hook, on the roll-back, or in the shop than they do on the road. If it isn't the engine that has sh!t the bed it's the transmission. The rear window has exploded a couple of times.
EChas3
08-06-13, 06:46 PM
A guy I worked with had his Mopar trans break in half. !?!
It was some sort of SUV/Crossover with about 75,000 miles on it. Sure, that's no virgin, but nowadays you'd expect better than that. He actaullay had to argue with the dealer to get any help with the repair at all!
