View Full Version : Putting Escalade on Lift ... any concerns??
BlueOvalKid
07-22-13, 12:37 PM
2005 Escalade ESV Platinum
I recently purchased the Escalade and am planning on some maintenance before taking a road trip next week.
With the wheel level sensors at each corner do I need to take any precautions when using a 2 post lift I have at my shop? I ask as with a 2 post lift you lift the chassis and the wheels hang and I don't want to mess anything up with the autoride suspension.
Any input would be appreciated.
I did try to search but the word "lift" seemed to give me the wrong results
MoistCabbage
07-22-13, 01:00 PM
No special precautions necessary.
the cadillac man
07-22-13, 01:14 PM
I second that don't worry about the shocks when the truck is on the lift I have has mine up on the lift and no problems
rfishoutofwater
07-22-13, 01:47 PM
No worries. Some vehicles have a switch to disable the air system for lifting but ours dont. Not sure about new models. Lift away!
BlueOvalKid
07-22-13, 02:24 PM
So the adjustable rods at each wheel, that tell the sensor the wheel height, don't need to be disconnected or anything prior to lifting?
wesyder
07-22-13, 02:25 PM
Thats a negative
the cadillac man
07-22-13, 06:05 PM
None do as far as I know unless you remove the compressor relay
YoshiMan
07-24-13, 10:41 PM
I've jacked mine up numerous times without any special precautions, and it doesn't specify anything int he factory service manual either.
