View Full Version : Alpine PXA-H800 and aeroforce gauge /nitrous install pics
spdmn75
07-20-13, 11:36 AM
So still have to finish up some plumbing of lines under the hood but interior is finished. I had used a JL audio clean sweep before with a trunk mount eq. This was running to 2 amps with JL separates and a 12". Sounded ok but did not have the adjustability I was looking for. So I moved up to the Alpine setup. This has a lot more features and can be adjusted on a laptop. So far it's been great. I ended up moving the volume and tune knobs to the glove box as they are not used with Alpine. I added the RUX control head to use as the master volume. It's not required but given the way this car is wired I needed it. I then moved my aeroforce gauge and added my other analogic gauge to the ash tray area. The nitrous window/wot controller is the HSW microedge mounted in the upper arm rest section of the center console. I also relocated the USB/audio in and cig lighter to a different area in the center console to add the arm/ heater and purge buttons. The other 4 black ones are to cycle through the pages on the aeroforce gauges.
http://i885.photobucket.com/albums/ac52/jmg61075/image_zps26961ac8.jpg (http://s885.photobucket.com/user/jmg61075/media/image_zps26961ac8.jpg.html)
http://i885.photobucket.com/albums/ac52/jmg61075/image_zps1224af99.jpg (http://s885.photobucket.com/user/jmg61075/media/image_zps1224af99.jpg.html)
http://i885.photobucket.com/albums/ac52/jmg61075/image_zps2a154491.jpg (http://s885.photobucket.com/user/jmg61075/media/image_zps2a154491.jpg.html)
http://i885.photobucket.com/albums/ac52/jmg61075/image_zps796c2596.jpg (http://s885.photobucket.com/user/jmg61075/media/image_zps796c2596.jpg.html)
http://i885.photobucket.com/albums/ac52/jmg61075/image_zps4085431f.jpg (http://s885.photobucket.com/user/jmg61075/media/image_zps4085431f.jpg.html)
http://i885.photobucket.com/albums/ac52/jmg61075/image_zpscf8cc7a4.jpg (http://s885.photobucket.com/user/jmg61075/media/image_zpscf8cc7a4.jpg.html)
The four clear LEDs are for armed(green) heater (yellow) radar detector alert(red) n2o spraying( blue)
V locity
07-21-13, 11:15 PM
Nice install! Very clean!
spdmn75
07-24-13, 03:16 PM
thanks, loving the adjustability so far of the Alpine unit. also has a road eq function that adjusts the sound based on additional noise entering the car
SecretWeapon
07-27-13, 06:49 PM
Wow. I am genuinely impressed with what you have done. Kudos sir.
spdmn75
08-04-13, 08:02 PM
Thanks. I may redo the trunk now as I just have a 12" mounted on the spare tire well
