: New CD Changers???
97 Eldorado
02-28-05, 02:38 AM
I'm looking to get a new CD changer for my 97 Eldo... what would be compatible? I want to get a pioneer 12 disk but will settle for a 6. I also want to keep the stock head unit to keep the original look.
03-01-05, 10:19 AM
Why not pick up a used Delco unit over E-Bay? If you have the cable in the trunk and are plug and play, it is a great way to go. My eldo cable was stored near the antenna mount under the carpet in the trunk. It had a jumper that I had to remove. I bought a Delco 12 disc on e-bay and then obtained a mounting bracket from a GM parts supplier for under $10. The unit then mounted perfectly in the trunk, the "theftlock" system instantly recognized the 12 disc unit and the source button is used to operate it. A new changer w/bracket et al was about $900. E-Bay bid was about $125 including shipping. Just do a little research on the one's for sale to make sure they are for your yr/model. It sounds great.....good luck.
