: EBC Rotor and Pad Upgrade (Bonus SS Lines with Motful RBC 660)
kanundrum
07-15-13, 10:37 PM
Front Rotor (355mm)
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash3/34725_272374569567884_989289984_n.jpg
Fronts Assembled
http://i42.tinypic.com/2ia9c8o.jpg
http://i44.tinypic.com/mavyug.jpg
http://i41.tinypic.com/20aq70j.jpg
Rears
http://i42.tinypic.com/mm3h93.jpg
Very Peculiar thing I noticed about the stock pad, the braking surface is cut by about 20 to 30% because for some odd reason who ever designed the pad decided to put grooves/valleys on the sides. This design makes no sense to me and if anything reduces the amount of the contact surface for the pad and the rotor. Also tricks the owner into thinking they have more pad left when in reality you have to get a new pad when your indicator starts hitting the valleys and not the backing plate of the pad.
http://i44.tinypic.com/2w2gf3o.jpg
Getting Stainless Steel Lines Installed on Thursday with a Motful RBF 660 Flush (Fluid dirty despite it being changed 15k miles ago).
TheCaptain
07-16-13, 08:16 AM
Sweet. I like the vented rotors!
kanundrum
07-23-13, 01:00 PM
Custom SS Teflon Lines if anyone is interested. The car Stops so much better now its at least a good 30% to 40% Braking Improvement.
128858
MoistCabbage
07-23-13, 01:19 PM
I have Ultimax rotors on my Seville, with RedStuff pads. Nice brakes.
The point of the slots in brake pads is the same as the slots in the rotors: To allow gasses and dust to escape from between the pad and rotor.
Chamfers are there mostly for noise reduction, and there are thermal reasons with performance pads as well.
30-40%??? You've reduced your braking distance by almost half?
kanundrum
07-23-13, 01:49 PM
I have 100% road tested it but Initial Feel is severely drastic, especially after SS Lines and Fluid. Car comes to a stop on a dime, the chamfer information is quite interesting how ever I can't think the pads were still not the best for brake/stopping force.
kanundrum
11-12-13, 03:48 PM
Update greenstuff was causing grinding going to redstuff soon.
kanundrum
11-27-13, 11:16 AM
Redstuff swapped in and its even better than the greenstuff. Greenstuff seems like it was bad as I tooke dit out only after 2 or 3k miles and it has cracks in the actual pads.
kanundrum
09-04-14, 01:30 PM
Update Redstuff feels like its fading under heavy braking. I am looking into big brake kit options soon but finding it very difficult due to the bolt pattern
njacobsen
09-04-14, 03:45 PM
Perhaps you should return to stock.
Thank you for sharing the results you had with the product. That is one of the values of these forums...sharing experience, good or bad, helps all of us.
SFVetteman
09-04-14, 05:47 PM
Redstuff are ceramic pads. They produce less dust that you can see but at a price of more brake fade. If you want a true performance brake pad then check out Hawk HPS, Hawk HPS Plus or EBC Yellowstuff.
Bill
MoistCabbage
09-04-14, 05:49 PM
Ceramics are less probe to fade, not more prone.
SFVetteman
09-04-14, 05:55 PM
If you want to believe that then go ahead, but I speak from real track experience of myself and others.
Bill
kanundrum
12-30-14, 12:56 AM
Unfortunately long term tests results are very weird. I will be switching to a different brand of rotors and pads as initial feel was quite great but long term tests result in lots of wear and braking improvement reduction. Most likely I will be going with stoptech rotors and akebono setup. No other manufacturer makes aggressive fronts and rears like Hawk HPS or Stoptech street series.
