: Climate Controls Sensor?
02-27-05, 10:02 AM
I have recently purchased my first Cadillac. It is a 2001 Cadillac Catera and I am loving every minute of it. I only have on problem so far. The passenger side climate controls do not work properly. The fan blows air, but it is cold even when set to 90 degrees. I was think about a temp sensor on the passenger side or maybe a fuse. Only problem with that is I have no idea where either is. Previous owner could not find owner's manual and I dont know where to begin. If anyone has any ideas that would be great.
02-27-05, 01:09 PM
Sounds like one of the mix doors is stuck or not working.
You can reset the doors (with the ignition in on position or the car running) by holding the auto and off buttons on the climate control for 5+ seconds with the key in the on position. This resets the actuator doors to control levels.
04-24-05, 08:15 PM
Same thing with my 97 cat ,i tried the trick you said Jeff but didnt work and i checked the fuses too
