View Full Version : Music Stored on Flash Drive
Stoofpilot
07-13-13, 09:00 PM
Since there is only one CD in the car, I copied multiple albums on to a flash drive using playlist from my iTunes. Funny this happen. None of the playlist names showed up in CUE but the album names showed up. Unfortunately, some songs from the same album were in different playlist so I got a bunch of duplicates and way too many album names.
Question? Does anyone know how to get the system to reconize the playlist names.
I found a work around that worked great. Went in to the folders on the flash drive. Did a shift select of all songs in folder then went to properties and changed album names to the playlist name of each folder.
Put the flash drive back in the USB port and now all of the playlist names appear under the "Albums". Works great.
CDN XTS
07-16-13, 12:24 AM
I posted extensively about Music on Flash Drives/SD drives, playlists and artwork - search under my name both sites XTS and CUE - that should assist you with playlists.
