: Imbedded youtube start times broken.
Hoosier Daddy
07-13-13, 10:53 AM
I didn't report it at the time so don't remember the exact time it started but no more than a few weeks ago. I guess I hoped or assumed it was a mistake that would be corrected without reporting it.
Youtube allows you to set a starting time for any video and even will generate the URL to do that if you pause while watching and right click to get that URL.
These forums supported that until some recent change.
This problem completely breaks numerous existing posts that involved long videos with just a short relevant portion well into them. And of course the problem prevents using videos this way in new posts.
So I hope the fix is made quickly.
For example, to start a YouTube video at 3 minutes and 1.5 seconds, just add #T=181.5S to the end of the URL. (#T means time, S means seconds and what precedes it is a number of seconds).
example:
If you entered: www.youtube.com/watch?v=xxxxxxxxxxxx#t=181.5s (http://www.youtube.com/watch?v=xxxxxxxxxxxxt=181.5s) as the video source while composing a post, the software will generate:
{video=youtube;xxxxxxxxxxxx]http://www.youtube.com/watch?v=xxxxxxxxxxxx#t=181.5s[/video} but with [] rather than {} around it.
You would then have to add the #t=181.5s back to the first part:
{video=youtube;xxxxxxxxxxxx#t=181.5s]http://www.youtube.com/watch?v=xxxxxxxxxxxx#t=181.5s[/video} but with [] rather than {} around it.
To recap: the recent change has broken start times in all existing posts that use them. And it would be nice when that gets fixed also have the software automatically carry the start value thru to the begining portion of the generated code. But please do NOT delay fixing the problem if it takes longer to do both. The fix is the most important part.
admin
07-17-13, 03:51 PM
The problem appears to have been caused by a change URL. The example that you provided #t=xx.xs does not work but if you use this code&t=xmxs (x being the numbers) it should work.
Here is an example of it
http://www.youtube.com/watch?v=qTENT9gQxCE&t=3m30s
you can go to this (http://youtubetime.com/) site and it will create the code for you as well.
- dm, community support
RippyPartsDept
07-17-13, 04:43 PM
that didn't seem to work ... started at the beginning for me at least
Kingoftypos
07-17-13, 07:17 PM
Aren't you given an option on YouTube itself to provide you with a time stamp? Whenever I click on the share tab, it gives me a box with the videos URL and to the right there's a check box that allows you to start the video at "this" time and what not.
I know this works on a desktop, but it doesn't appear to give an option for mobile. At least not in the iPhone 5.
KOT
Hoosier Daddy
07-17-13, 08:13 PM
KOT
Yes. I covered that in the original post.
But as Chris said, Admin's new method does not work.
Admin, please confirm that it worked for you (as opposed to: should have worked but you never tried).
Because it doesn't work for anyone who has tried it yet and to be honest did not make sense for the forum software to suddenly force you to change the # (that YouTube provides and uses) to an &. It wasn't a case that # caused the forum to go wacko because # worked just fine in these forums as long as I've been here and in every other forum I've used since the dawn of YouTube adding a start time option.
admin
07-18-13, 09:30 AM
Hey guys,
Sorry I guess my edited post did not save correctly. I edited it to say I would need to look into the issue further. For some reason the time stamp option is not working with the video coding. I will update you when I receive more information of what could be causing the issue.
RippyPartsDept
07-18-13, 10:31 AM
Just as an fyi, both methods (#t=xx.xs and &t=xmxs) work just fine and are proper Google/YouTube conventions for linking a start point in a video
why the forum won't accept the time codes is probably nothing to do with Google/YouTube and more to do with vBulletin
admin
09-13-13, 04:09 PM
n7eKmwGJo_I
Hey guys,
Sorry about the delay in getting this fixed but the timestamp issue with youtube is fixed. If you would like to post a timestamped youtube video please use this BB code.
Also Note - Make sure to switch all { to [ to make the code work
{youtube="XX"}video code{/youtube}
Replace the xx with the time you would like to start with.
The video code is located at the end of the youtube video. In the example below I highlighted it in red.
[w w w .youtube . com/watch?v=[/url]n7eKmwGJo_I
RippyPartsDept
09-13-13, 04:45 PM
testing
RNuUgbUzM8U
Kingoftypos
09-13-13, 07:06 PM
testing
<a href="http://www.youtube.com/watch?v=RNuUgbUzM8U">YouTube Link: 87</a>
Idk about you. But this started at the beginning for me. Using the Cadillac App on iPhone 5.
KOT
RippyPartsDept
09-14-13, 04:46 AM
starts at 1:27 (87 seconds) on the desktop (i'm using chrome on vista and xp pro)
admin
09-16-13, 12:55 PM
KOT
I think this could be because of miscommunication between the app and YouTube. I'm not noticing an issue right now on FF but I tested it out on the AG app as well and once I clicked on the video it took me to youtube and the video started at the regular start time.
