View Full Version : CEL on getting codes of running too lean.
Jneedom14
07-12-13, 02:15 PM
It doesn't feel like nothing is wrong with it. I just want to know how bad it is for my car and how can I fix it.
Guy.Seminerio
07-12-13, 03:13 PM
it's probably not detrimental to the health of your car. I'm guessing your post means it doesn't feel like anything is wrong. I'm a perfectionist so I'd get it fixed. I don't know of any long term issues you can run into leaving this alone. There is always the band aid approach of putting higher octane gas in the car.
curtc
07-12-13, 03:41 PM
If you have the Northstar check your intake manifold bolts...They are known to loosen.
Ludacrisvp
07-12-13, 03:56 PM
just don't over tighten them ... they are hardly past finger tight ... 89 INCH LBS is spec.
dkozloski
07-12-13, 04:56 PM
Check the intake manifold bolts.
Jneedom14
07-12-13, 07:03 PM
Now after driving it today at idle it starts to get rough but anytime above idle its perfect. What could this be? I just got it out the shop for HG and a valve job so im not trying to do any damage cause this car has to last me another year. And I an still running lean on both banks what could cause it to run lean.
curtc
07-12-13, 09:20 PM
Have you inspected the intake manifod bolts yet as recommended by more than one of us???? That WILL cause both banks to run lean....
dkozloski
07-12-13, 10:29 PM
What year is this pig?
1BadCadSTS
07-13-13, 07:25 AM
Hi I have a problem and I want you to help but ill be completely general and vague in providing you any information to help...
Fixed
Year make model engine size would go a long way towards helping us help you. Also a stop by an auto parts store and getting the codes scanned and then giving a us those codes would be nice...
Help me help you. HELP ME HELP YOU!
Jneedom14
07-13-13, 11:41 AM
It's a 2006 Cadillac STS V8 4.6l I don't remember the codes they were just bank 1 too lean and bank 2 too lean. Please help I apologize for not giving ample information.
curtc
07-13-13, 04:41 PM
Again, there's a good chance those lean codes are being set by loose intake manifold bolts...Have them inspected or check them out yourself...
dkozloski
07-13-13, 08:17 PM
Check the intake manifold bolts. Try it. You'll like it.
1BadCadSTS
07-13-13, 08:37 PM
X100000
Intake manifold bolts or the tb plenum gasket.
