TeagueJT81
02-23-05, 03:30 PM
I feel like a complete idiot with this one. I was driving the car home yesterday, and it began steaming out of the right side of the hood. I pulled into a restaraunt parking lot, where I noticed the coolant in the overflow tank had expanded so much it had popped the lid off. The upper radiator hose was heavily pressurized and very, very hot, and there was coolant all over the engine on the passenger side, as well as on the passenger side floorboard inside the car (I'm pretty sure that the leak inside the car came from a bad heater core, but I know it couldn't be responsible for the whole thing). I limped the car home, since the owner of the restaraunt wouldn't let me leave it there even until a tow truck could come (it's a frumpy little five-star place) and my house wasn't too far away, let it sit for about an hour and a half, refilled the coolant, and drove it the all of 25 feet from the road to the driveway. By the time I shut it off, it was steaming violently again.
One friend of mine thinks the heater core was responsible for everything, which I doubt. Another, who knows a bit more about cars, says it's the thermostat. After reading several posts on head gaskets, I'm leaning towards a blown head gasket. My reasoning is as follows:
1. It came up suddenly, after I had been driving the car for two days.
2. Coolant was all over the outside of the block, including around the head.
3. When I pulled the car into the driveway, it wasn't even on for two minutes and had had lots of time to cool down. The only thing I can think of that would have caused the coolant to boil so quickly is superheated exhaust gases.
4. The upper radiator hose was pressurized and extremely hot. A jammed-shut thermostat could cause the hose to be pressurized, but I don't think it would be as hot as it was.
Is there anything else that could cause this problem? If it is the headgasket, is there anything else I should do when I replace them (since so much of the engine is going to be taken apart)? I want to replace pushrods, valve lifters, and every gasket from the head gaskets up, as well as cleaning out cooland and air passages and overhauling the throttle body. I want to get everything done I can in one swoop as long as it doesn't require pulling the engine.
Thank you all once again for helping someone who's gotten himself in over his head.
And I'll post pictures of the car tonight as soon as I get home from work. I promise this time!
- Joe
- Joe
