: 94 Fleetwood Hearse windows won't go down
Faith76
07-10-13, 11:38 AM
Help! It's hot and it smells funny in there (no a/c either!) Does anyone know where in the fuse panel the fuse for the windows are, or have any other suggestions? Maybe a fuse diagram? Thanks!
jamespowers
07-10-13, 01:51 PM
There isn't a diagram in the cover?
turbojimmy
07-10-13, 03:15 PM
They don't even try? Could be lots of things.
You should get a FSM or subscribe to alldatadiy. The info alldata has for the '94+ Fleetwoods is fairly complete.
carnut
07-10-13, 03:42 PM
Not controlled by a fuse! windows are wired thru a circuit breaker. Most likely you have no power to the master switch on the drivers door. Pull the switch up and partially out of the arm rest and with a test light, confirm you have voltage to the switch.
Faith76
07-10-13, 05:46 PM
Thanks, as soon as it quits raining here, I'll go try that.
