: Samll leak after install of 160 Thermo?
LSUFoolsball
07-09-13, 12:23 AM
Hey guys I might need help. I changed the Thermostat and I have a small leak. I have tighten to spec and I still have a small leak. I was seeing if not lining the rubber gasket right would be the issue. Just want to see what you say before I break it down again.
Thanks
LSUFoolsball
07-11-13, 11:41 AM
Anybody?
cruiser68
07-11-13, 03:02 PM
I would check the rubber gasket and use scotchbrite to clean up the metal mating surface before re-installing. Also you could compare the old/new gaskets to see if there is any differences.
LSUFoolsball
07-12-13, 05:24 PM
Well there is not gasket on the Housing now there is one on the Thermostat. I think I read somewhere it has to be lined up. If not it might leak some.
Snotty Boom Body
07-12-13, 09:19 PM
Shouldn't there be a gasket or rubber O-ring to seal the housing to the motor
LSUFoolsball
07-13-13, 08:13 AM
I dunno I did not notice one. I thought about RTV to seal it but that stuff is messy.
ClarkkentCTSV
07-13-13, 09:18 AM
I remember when installing my 160 thermostat that it has to go in a certain way or else it would leak. It will go into the hole, but it wound not seat properly and you will need to find the sweet spot for it to fit correctly and not leak. Remove the housing and then rotate the thermostat until you feel it seat correctly.
miamictsv
07-13-13, 12:01 PM
My Mechanic just told me that i also have small leak from my 160 thermostat. I will service it as soon as i get my bigger issue resolve. I need to replace my evaporator due to leaking. $700 labor ... ouch :(
LSUFoolsball
07-14-13, 03:01 PM
I think it has a notch at the top. I will take it off and try again. Thanks.
CavemanB52
07-15-13, 06:09 PM
Mine is fine.
THE////V
07-16-13, 01:27 AM
I'm interested to know do any of these engines run at 160 deg. When driven hard or even on a hot day with the air on ?.. I was thinking about it I have din it and every car I installed on on unless it was 20 deg. Out still ran over 200 . How about the V horsepower = heat.
miamictsv
07-16-13, 02:59 PM
Mine runs at around 200 deg when fully warmed in South Florida Heat. Before it will run at around 210-215 deg. I am boosting 15PSI as well.
CavemanB52
07-16-13, 05:49 PM
I'm only boosting to 13. Used to run about 195F stock. Now I run the Track Attack Hx and a 160 thermostat today I noticed running at 175F after several pulls and running for an hour.
rbzstsv
07-16-13, 10:33 PM
06 sts v here. Car runs 178 tstat. Before hx by TimC it was running about 198 to 210 with iat2 from 170-190 depending on driving style. After hx/jabsco pump install the car never runs hotter than 190 - 195 with iat2 at 115-160 (85 to 90 outside), even after a long stretch of spirited driving.
Gary Wells
07-24-13, 12:00 PM
Check the rubber boot at the top of the metal pipe.
Mine went bad at & developed a hole / separation at the inside of the 90˚ bend on the rubber boot.
$30 for that stupid little rubber boot.
