View Full Version : help spark plugs and a few questions
mr888
07-08-13, 10:07 PM
hey guys I'm new to this form , I just bought a 2008 STS 150,000km it has a engine code look that up seems to be misfiring on cylinder number 3 when I'm going on the highway at 100km it seems to sputter when and when I step on the gas and go over a hundred it goes away and sometimes when I step on the gas hard I feel as if the vehicle is accelerating a bit by itself..
I was planning to change the spark plugs erase the code if it comes back I was going to switch a coil for another one to see if it misfire on cylinder number 2 I was also going to clean out the throttle body
my questions are am I taking the right step?
also I was doing some reading around do I have to remove the intake to replace the spark plugs or on the 3.6DI it is not needed to ? can I do this myself?
also my car is in park and the the display is beeping telling me its not I have to wiggle it around for awhile for it to go away..?
EChas3
07-09-13, 12:06 AM
Soon, you may need to replace the shifter. Some members have been able to get by with adjustments but there is a known issue.
mr888
07-09-13, 01:53 AM
that would suck does anyone know how to disable it or adjust it?
Ludacrisvp
07-09-13, 09:18 AM
http://www.cadillacforums.com/forums/cadillac-sts-forum-2005-through-2012/282264-automatic-transmission-shift-linkage-adjustment.html
KRSTS
07-09-13, 09:32 AM
You do not need to remove the intake manifold to replace the spark plugs on the 3.6L DI engine.
mr888
07-09-13, 04:36 PM
thanks a lot for your help guys did the spark plugs cars running good now thanks again :)
