: 07 cts 3.6 leaking water under glove box!
raven07cts
07-07-13, 10:48 PM
I have a 07 cts 3.6 and my car just started leaking water from under the glove box on the passenger side. I took the plastic cover off from under there but didn't see anything. Please help!
jcornv15
07-12-13, 08:14 PM
YOU HAVE A CLOGGED VENT TUBE FROM THE A/C SYSTEM. yOU NEED TO RAISE THE CAR AND POKE IT OPEN WITH A COAT HANGER. IT SITS BEHIND THE TRANSMISSION JUST BEHIND SOME HEAT SHEILDING . IF YOU CANT RAISE THE CAR THEN PULL BACK THE DRIVER SIDE CARPET NEXT TO THE GAS PEDAL AND PULL THE 2INCH DIAMETER BLACK HOSE FROM THE GROUND. WATER WILL FLOW EVERYWHERE SO BE PREPARED. AFTER THAT CONTINUE RUNNING YOUR A/C STILL THE WATER IN THE BLOWER DRIES OUT(UNLESS YOU KNOW HOW TO GET IT OUT THROUGH THE GLOVE BOX) THERE'S APPROXIMATELY 1 CUP OF WATER SITTING IN THERE. ONCE YOU CLEAR THE OBSTRUCTION YOU SHOULD BE FINE.
