: Obdi or obdii ?
85 FLEETWOOD COUPE
07-07-13, 01:47 PM
just something i was thinking lastnite,i got a 96 fleetwood, i had changed out my pcm/ccm out of a 94 fleetwood, so would i ave to use the obdII still bacause its a 96 or do i use the obdI because i switched stuff out from a 94 witch is a obdI????
turbojimmy
07-07-13, 02:08 PM
So you put a '94 PCM in a '96 Fleetwood? And it works?
85 FLEETWOOD COUPE
07-07-13, 03:04 PM
Well i had the 1 under the hood flashed before installing in the 96, should i have keep the 1 in the trunk the 96 1 or leave the 94 in there? The car runs, i had my steering column out the 94 to
jayoldschool
07-07-13, 04:07 PM
The 96 OBD2 PCM is a completly different part number than the 8051 OBD1 PCM used in the 94-95 B/D cars. You need a 96 PCM.
85 FLEETWOOD COUPE
07-07-13, 04:26 PM
So you saying if i used the obdii it wont show correct codes? But i flashed the pcm shouldnt that matter????
But some 1 told me if i used the pcm and the ccm it would work on my 96
jayoldschool
07-07-13, 04:56 PM
The OBD1 PCM is different, even if flashed. It uses a different chip set, and looks for different resistance on the knock sensors. You need a 96 PCM in a 96 (and a 94/5 in a 94/5).
People will tell you lots of things. If a guy tells you he's Batman... it might even be true.
jamespowers
07-07-13, 05:03 PM
People will tell you lots of things. If a guy tells you he's Batman... it might even be true.I am Batman.:cool2:
cadillac kevin
07-07-13, 05:09 PM
I am Batman.:cool2:
No, I'm batman. We've never been seen in the same room together. Coincidence? I think not!
silverfox103
07-07-13, 05:13 PM
I agree with Jay, it makes no sense to do that. The 96 is made to run on an OBDII.
Tom C.
jamespowers
07-07-13, 05:14 PM
No I am Batman. I have been seen in the same room as Batman---because I was smart enough to use Alfred as a decoy.
85 FLEETWOOD COUPE
07-07-13, 05:57 PM
Im sorry it is a 96 pcm i just had it flashed,the ccm is a 94 along with the steering column i had installed would that matter or should i plug up back the 96 ccm in the trunk?
This guy told me to use the ccm because i was going to use the 94 steering column with the 94 original key,does this makes sense to you guys, i had to bypass the column but it starts up
turbojimmy
07-07-13, 07:36 PM
That makes more sense. I *think* the CCM is the same. If you've bypassed the PASS KEY system, and it works, why mess with the CCM now?
85 FLEETWOOD COUPE
07-07-13, 08:23 PM
I did everthing at 1 time, i did the ccm becaus i thought the 94 original key would read it and would start
85 FLEETWOOD COUPE
07-08-13, 04:12 PM
So now my question is would the obdii reader still read if it had the 94 ccm in the trunk or dont matter?
turbojimmy
07-09-13, 01:44 PM
It doesn't matter. Only OBD-II powertrain codes are reported on the '96 and accessed via the OBD-II port. Body codes are the old style, like on the earlier years and can be accessed through the HVAC module.
