View Full Version : Front cadillac emblem
Eric Hagan
07-06-13, 10:56 PM
Anybody have any ideas on how to remove/replace the emblem on the front grille. The red is starting to fade and I want to replace it.
Rich08
07-07-13, 12:05 PM
Heat it up with a hair dryer and pull it out. It has to pins that align it in place.
LowNslow
07-08-13, 10:03 PM
I just left mine sitting in the driveway vs garage. The Texas heat did the trick & peeled off fairly simple.
Rich08
07-08-13, 11:01 PM
Texas has some crazy hot weather, that's why we moved to NJ.
Ran-Dom32
07-09-13, 09:14 AM
use a piece of fishing line, slip it behind and saw it off, works great
wyoescalade
07-09-13, 01:42 PM
I have a front pitted Crest/Wreath and a rear Crest/Wreath that is breaking inside of itself, and the wreath on the rear has the chrome finish coming off. I have also noticed that the wheel hub covers crests also have faded and the red in the crest is now pink. I have attached a picture of my rear crest/wreath.
123914
Holaday
07-09-13, 03:36 PM
This seems to be a continuous problem. Is there a crest available that is only silver so it would not need to be replaced in a couple years?
Mike141
10-11-16, 08:03 PM
Ok, does anyone have a part # for this? Mine is an 08 and both the front and rear emblems are faded and need replacement. Thanks
2kflhr
10-11-16, 08:44 PM
use a piece of fishing line, slip it behind and saw it off, works great That works like a champ. Growing up in a body shop I've seen it done many times myself. I personally use Flax Twine as it is more durable and doesn't break as easy.
http://www.wholesalegmpartsonline.com/productSearch.aspx?ukey_make=1023
smittomatic
10-11-16, 08:52 PM
I always use gmpartsdirect.com for reference and part numbers. Then I look for a better deal elsewhere. I just replaced my front and back and got pretty good deals on eBay.
http://www.gmpartsdirect.com/cadillac/escalade-esv/22985035/2008-year/platinum-trim/6-2l-v8-gas-engine/body-cat/grille-and-components-scat/?part_name=emblem
laselvasurf
10-16-16, 04:59 PM
If you need an emblem, I accidentally ordered a front when I meant to order the rear. It's new and never installed. Paid $20 from eBay for it and would give it to you if you pay shipping. Let me know.
godsdiablo
10-16-16, 07:17 PM
Heat it up a little with a blow dryer not heat gun and get your finger nails under it . do NOT use a screw driver
Mike141
10-16-16, 08:50 PM
Sure, I'll take it. Can you send me a pic of it to miked1962@comcast.net and we can set up payment and shipping.
