View Full Version : front wheel hud replacement, step by step
boomys10
07-01-13, 08:38 PM
hey hey, had to replace another wheel hub/bearing. figured I would through up a quick step by step so if anyone else needs it done you can see how easy it is.
1, jack up car
2, remove tire
3, locate the two bolt that hold the caliber onto the knuckle (18mm)
4, once bolts are completely removed, remove rotor and place on the lower control arm
5, remove the torques screw on the front of the rotor (t30)
6, remove rotor (if slightly rusted in place, lightly tap with a hammer to knock the corrison off)
7, locate the three bolts on the back of the wheel hub holding it to the knuckle (13mm)
8, disconnect the hub from the wire harness
9, remove the three bolts and remove the wheel hub
10, reverse the steps and your finished.
pictures to follow.
Guy.Seminerio
07-01-13, 08:43 PM
Nice. Ill be referring to this when I inevitably have to replace mine. Thanks.
boomys10
07-01-13, 08:55 PM
http://s164.photobucket.com/user/shnblkblt/library/wheel%20hub%20fix?sort=3&page=1
