: 1984 Eldorado - Replacing BOSE speakers
07-01-13, 05:50 PM
I have a 1984 Cadillac Eldorado Biarritz 2 door coupe with Bose speakers. I recently replaced the factory stereo with an aftermarket Kenwood Stereo and everything is working fine. However, the speakers sound terrible. I went to Crutchfield.com and Amazon.com, and they both said the replacement speakers are 4X6 for the front speakers and 4X10 for the rear speakers. When I look at the door speakers, they appear to be 4 inch speakers (not 4X6). When I look at the rear speakers, they also appears to be 4 inch speakers with an amplifier connected.
1. Do I remove the door and rear Bose speakers ? (The door speakers are the majority of the door side panel and I am wondering how I would fill that in); or do I retrofit the current Bose configuration?
2. Should the front speaker size be 4 inch (or 4X6)?
3. Should the rear speakers be 4X10 (or 6X9)?
My goal is to remove the Bose speakers and install aftermarket speakers, but I'm stumped. I went to Car Toys, and the guy told me he did not know how to install the speakers (because he never worked on an older caddie before). I thoroughly checked this forum and found some good articles on how to remove the front and rear speakers, but I need some help figuring out speaker size and installation. Any help would be greatly appreciated.
07-11-13, 08:56 PM
Don't let anyone BS you and tell you anything is impossible. My 88 will have 8" pro audio fiberglass ported enclosures in it when I'm done. Anything is possible. First thing you need to do is pop those front door grills and see what you got. 2nd, test the impedance of those speakers, if they're BOSE, they're probably 2 ohm speakers. I would see how much room you have to play with and get some 6.5" components. That's the biggest upgrade you can do to those to start. You'll need to cut out and get some baffles made, but that's no big deal for a decent shop.
08-05-13, 02:02 AM
Thank you for the advice. I took the speakers out and took a look at the Bose speakers. Both front and rear speakers were 4 inches. I had room to install a pair of Alpine 5 1/4 in the front with some modification and 4 inch Alpine speakers in the rear. The sound improvement was definitely noticeable . Later, I installed 1 Alpine SWS 12 inch woofer in the trunk in a ported box and a MRV-500 Alpine amplifier.
