: Parking Light Help
justinjohnson0718
07-01-13, 01:37 PM
I have a 02 escalade 6.0L and I'm trying to find some help with the parking lights they stay on sometime and the only way to turn them off is to take the fuses out of the fuse box. This only happens sometimes. I've tried removing the headlight switch to see if that'll stop them but it does help the problem they still stay on. Could this be linked anyway to my security system? Should the plug on my headlight switch have constant fire on two of the wires and the plug at all times when the battery is plugged up and the headlight switch is not plugged into the harness? Has anyone else had this problem and can give me some pointers on where to start to fix this problem. Thanks.
the cadillac man
07-01-13, 03:00 PM
Sounds like a bad switch or stuck relay if not a bad sun load sensor(its on the top of the dash)
Two of the wires in the headlight switch harness is hot at all times
justinjohnson0718
07-01-13, 05:22 PM
I tried taking every relay out of both fuse boxes and the lights would still not turn off. Which relay am i looking for in particular? And if the headlight switch was disconnected from the harness the parking lights still stay on could that still be the headlight switch in that case? Also where can i find the sun load sensor? Is it the two black pieces in the middle of the dash or the little red light on the left side of the dash kinda next to the tweeter? Thanks for your help.
justinjohnson0718
07-01-13, 06:28 PM
Also when they do turn off on there on it only last a hour at most then they turn right back on i removed The batt cable and put back on several times too see if some swicth or relly was stuck still no change they want turn off unless the fuses comes out thanks for the help again
the cadillac man
07-01-13, 08:44 PM
Sounds like stuck/bad relay
Bad switch(I had that happen on my moms 02 because the dash lights wouldn't work unless the dimmer was in the dome light position)
Not sure but it could be the bcm failing
The under hood fuse box has a layout of where each fuse and relay is at
I know this may sound crazy but is the sun load sensor covered(it is located in the middle of the dash between the defrost vents)
Given how it has a delay before the lights kick on it sounds more like the sun load sensor is bad
justinjohnson0718
07-01-13, 10:36 PM
Basically mine is doing the same thing that you were describing about the dash lights not working unless you turn them on with the dimmer switch..do you know the name of the rely off hand what it would be called in the fuse box cover? And one last question how would you test the sun load sensor? Thanks again.
the cadillac man
07-01-13, 11:35 PM
I would replace the headlight switch first its the cheapest and easiest to replace
The relays are cheap
The park light relay is in the under hood closest to the front and near the large fuses
The low beam relay is three away from it its next to the ones for the fog lights and horn and beside the ac compressor relay
The fuses for the headlight bulbs are the closest to the front left (the high beam relay is next to them)
The lid of the under hood fuse has a layout of the box with each fuse and relay on it(its also in the owners manual if you have it)
As far as testing the sun load sensor I have never seen one fail but I wouldn't mess with it till I made sure it wasn't the switch or relays first(as those fail more often)
justinjohnson0718
07-02-13, 10:57 PM
Update: I replaced the headlight switch and the relay today, still no change, I found the fuses to unhook the front and rear parking lights, I can't the fuse to unhook the tag lights.
When I start the vehicle at night with the headlight switch in the auto position I get no dash lights without turning the dimmer switch up... Also the digital fuel gauge at the bottom of the console turns off when I turn the headlight switch to the on position and it doesn't come back on until you turn the headlight switch off and on position and leave it on auto position... I'm thinking it may be the bcms like you were saying before, but I'm not sure, what are your thoughts on this now? Thanks for all your help again.
the cadillac man
07-02-13, 11:41 PM
I would want to check the grounds but it does sound like the bcm
Let me check my wiring diagrams and see if I can figure out what is the likely cause
justinjohnson0718
07-03-13, 07:15 AM
Ok sounds good Thanks man
